Results 11 to 16 of 16
- Apr 2008
- 6,237
October 18th, 2010 01:54 AM #11*niky: I remember reading a post from you in some other thread about you installing a Unichip on your Crosswind and received a minimal performance gain of 5-10hp. Or was it something else? Pardon me but I'm really not that good with the internals of the car. But would a Unichip work in cars higher up in the Isuzu ladder like the Trooper, Alterra and D-Max?
October 18th, 2010 03:24 AM #12
Piggyback ecu will work on the 4JX1 and 4JJ1 engines, yung 4JH1 ng 1st release d-max is mechanical I think?
If you want the crosswind to go faster, change the engine to a 4JG2-TC (Power=125ps & torque=325nm) , just don't know if it'll fit. malamang snug fit. Or a 4jb1-t which will surely fit. Tapos differential to accommodate the added power.
October 18th, 2010 10:37 AM #13
That was the alcohol injection. Another guy got a bigger boost, 10-15 hp worth, so it might just be my turbo.
Like blue gambit says, the Troopers and Alterras can be chipped. There's a cheaper solution than the Unichip for diesels... the VTech Redbox. But I don't know if there's one specifically for Isuzus.
- Apr 2008
- 6,237
October 18th, 2010 10:51 AM #14I see, but is the VTech Redbox available here? Does it extract as much power out of the engine as the Unichip? With this in mind, I might consider chipping our Trooper in the future. Oh and is there something wrong with your turbo?
October 18th, 2010 11:06 AM #15
Maybe age and wear. That unit I got from my Dad, and he wasn't so keen on regular oil changes. It could also be due to the automatic transmission. Might be slipping too much under boost.
February 11th, 2011 02:57 PM #16
i'd still go for the sportivo!when it comes to the engine, it's reliable even though low charged turbo pa sya and medyo mabagal compared to the innova which has a more faster & comforatable ride but has that a problem with it's d4d engine. sa porma, i'd still prefer the sportivo, the innova is much more lower...just go for what you believe is best for you!
high idle RPM at engine start
