Page 1 of 2 12 LastLast
Results 1 to 20 of 37
    Jun 2009
    share ko lang yung mod ko.
    almost 1 week ko na sya gamit. kaya ko sinubukan para mabawasan pa yung emission ng hi-lander namin. ok naman sya, siguro almost half din ang nabawas sa usok ng sasakyan at nabawasan din yung mabahong amoy.
    sino pa dyan ang may ganito? paki share naman experience nyo.
    Mar 2003
    how much did you get that for?
    i used to have my jb1 fitted with it but took it it off after top overhaul, nakakasikip kase sa engine bay! but it did serve its purpose (i think); now it's collecting dirt in the garage, i got mine at around 4k (IBEX brand)
    Jun 2006
    where and how much did you get that? ganda!
    Jun 2009
    php1845 sya sa blade twc yung brand. pakiramdam ko ang mahal kasi sa blade nga(mahal kasi sa blade). pero comparede sa price ng ibex na php4000 mura na pala. ok na rin kesa pumunta pa ako ng banawe.
    sa tingin ko effective naman sya kasi may trace ng oil sa inlet nung tank. at nabawasan nga yung usok ng hi-lander namin. medyo tuyo na rin yung intake di tulad nung wala pang oil catch tank basa ng oil yung intake.
    Jun 2006
    usually nilalagay talaga yan to lessen the emission of the engine.
    Mar 2003
    blade?! i never thought they'd carry those products! yeah, just like you said, i've known them to sell only accessories...and way overpriced at that.
    yeah, i'd say that's cheap, although mine was bigger; hence, it needed more room, considering the already cramped engine bay by default;
    as to effectiveness, proven naman nga yan, but in my case...the leak was coming from other sources too, kaya i was not able to really guage.
    more recommended ang mod na ito for turbo engines because of the amount of blow by driven by the turbo, but good then for older diesels for the same purpose.
    Feb 2010
    Sir where do you connect the other end of the 2 hoses? can you post pictures on that part? Thanks. . . kaya bang i-DIY?
    Jun 2009
    pwede i-diy yung oil catch tank pero ako bumili na lang para mas maganda malamang kasi kapag ako gumawa panget hehehe
    yung installation pwedeng pwede i-diy lang kasi hahanapan mo lang ng pwesto yung oil catch tank at ikakabit mo lang yung dalawang hose
    yung isang hose sa vent ng valve cover tapos yung isa sa may intake
    huwag nga pala kayo gagamit ng clear hose lumalambot kasi tapos natitiklop
    pinalitan ko ng braided hose yung sa akin para mas matigas
    Jul 2013
    https://fbcdn-sphotos-f-a.akamaihd.n...02425792_n.jpg
    heres mine install on our ADVENTURE GX UV EXPRESS and 3 times na ako na smoke pasado.......
    Apr 2010
    *homework
    question lang sa hose.
    garden hose ba ito?
    gaano nyo na katagal gamit?
    di i ba lumalambot kapag mainit at nag ko-collapse yong papunta sa intake?
    TIA.
    Chemical hose yata young ginamit Dyan. I used to have one but it restricted the turbo 4m40s breathing. Nag d.i.y. na Ako. Pure 1/2 fittings. Ok agad
    Apr 2010
    My share: DIY OCC;
    Quote Originally Posted by ezrydre View Post
    My share: DIY OCC;
    sir ano engine mo. san mo nabili yun gamit mo? and how much what brand , my new sportivo gusto ko din lagyan .meron ka contact
    Apr 2010
    Thats Strada 2.5 DiD non-VGT.
    DIY lang yan OCC ko.
    If you have the money, I suggest buy a decent OCC.
    There are sellers in sulit.ph.
    I suggest you get the one that you can open the top to put some wire mesh.
    If you can get one with the drain port, the better.
    Also, make sure to get the one with the same nipple size as your breather outlet.
    Usually, 9mm at 16mm lang yan. Diesel mostly is 16mm. But, better check yours.
    Jul 2013
    negative sir diko alam kung garden hose yan kasi noong binili ko yan na po yong kasama mga 1200 or 1400 ko nabili sa sulit sir
    Aug 2013
    May DIY OCC project ako ngayon for my 2001 Isuzu Fuego 4x2 4JA1 TDi engine, pag okey na, mag-post ako pictures. Surplus Korean PS fluid reservoir ang gamit ko, will install 16mm inlet and outlet pipes and put Scotch Brite stainless steel shavings inside (to help condense oil vapor) na nabibili sa ating mga suking supermarkets. Ihanap ko ng magandang location sa engine bay. Estimated cost - Php500.00
    Eto d.i.y. catch can ko... just sharing
    Sent from my GT-I9300 using Tsikot Car Forums mobile app
    Aug 2013
    Ano laman ng diy occ mo or is it just plain can with inlet and outlet pipes?
    Quote Originally Posted by johnjoseph View Post
    Aluminium sponge
    Aug 2007
    installed a DIY oil catch can today using a half height clear water filter housing and 5 ft. 5/8" chemical hose ,6 stainless clamps, some brass and GI fitting. stuff some stainless mesh inside the filter to filter out the oil mist coming from the rocker cover.
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
Oil Catch Tank
