Results 1 to 9 of 9
- Apr 2013
- 2
May 20th, 2013 02:58 PM #1Hello fellow Isuzu Car Owner, meron ako Crosswind XUVi na 2006 model. Napansin ko lang kasi recently na medyo mausok na siya ngayon. Meron nag recommend sa akin pa-calibrate ko injection pump. Pero nung pina-check ko sa CASA, wala naman daw problem sa injection pump and hindi naman daw kelangan ipa-calibrate ung injection pump. Meron ba kayo same problem with your crosswind? Any suggestion or help will be highly appreciated. Thank you!
May 20th, 2013 05:18 PM #2
Black smoke? Clean out your exhaust with a garden hose, and stuff a bottle of injector cleaner in the tank. Observe.
May 20th, 2013 08:09 PM #3
- Jan 2011
- 193
May 21st, 2013 09:45 AM #4Sorry, I cannot read Tagalog, but this article will tell you how to read Diesel Smoke Signals.
Visit Diesel Smoke tells YOU a Story…
Ciao!
Uncle Nick.
- Apr 2013
- 2
- Jan 2010
- 12
March 12th, 2014 05:27 PM #6
March 12th, 2014 08:42 PM #7
^bro, can you please guide me to where the pcv is located? i've been inquiring about this a couple of times but to no avail.
TIA!
March 12th, 2014 10:29 PM #8
may hose na nagkokonekta sa intake hose or manifold sa valve cover....trace mo lang tong linyang eto at pagdating mo sa may valve cover ay yun na yung breather nya. hth
sa TS, baka maaaring makatulong din ang 2T sa black smoke reduction mo...kasi talagang effective sya sa kaso ng sasakyan ko.
- Jan 2010
- 12
March 18th, 2014 11:49 AM #9from engine front (fan) way to the rear may black hose sa engine cover were its other end connect to intake tube (airfilter tube) ......
Good thing you don't have an oil pressure gauge. It'll make you think twice about going 50.
Thick (20W-50) vs Thin (5W-20) Engine Oil Tested
