Results 21 to 30 of 31
November 23rd, 2003 11:07 PM #21
di na ba pwede i-straight kung baluktot? kung yung lower part ang baluktot, pano ko i-straight yun kung ayaw ng lumabas?
Signature
- Sep 2003
- 77
November 25th, 2003 10:56 AM #22hmmm...have someone turn the radio on. I-assist mo yung antenna when going up para ma fully extend sya. Pre di ko nakikita yang unit mo pero konting adjustment lang yan. Slight lang ang pagkakabaluktot nyan. Tiyaga lang at ingat para maayos yan.
- Aug 2008
- 1
August 5th, 2008 07:38 AM #23Pwede ba ang surplus power antenna taken from RHD units install sa Orig LHD unit?
Thank you!
- Apr 2008
- 6,237
August 24th, 2008 11:57 PM #24May isang beses nangyari iyan sa amin. Ayaw pumasok ng todo. Ang ginawa pinakita at pinalitan ang antenna (ung stalk mismo) ng isang 2nd hand.
August 25th, 2008 10:06 AM #25
mas matindi ang akin! hindi na bumababa..
nasunog na ata yung motor ng antenna eh...
August 26th, 2008 08:29 AM #26
Power antenna for trooper is around five thousand plus. But if your motor is ok, you can buy the antenna itself with the plastic chord inside at 1800. I did it my self, just have to be patient and cool headed when doing it. Rememe\ber to remove the unneeded teeths if not it will lock.
August 28th, 2008 10:52 AM #28
August 28th, 2008 07:43 PM #29
thanks thanks.. siguro bibili nalang ako sa walco tapos sa iba ko nalang pa install..
August 28th, 2008 08:37 PM #30
Xiaomi E-Car
