Page 1 of 3 123 LastLast
Results 1 to 20 of 42
    Aug 2003
    I am thinking of buying a crosswind 2nd hand. Among the different models, which one is the best value in terms of accessories, ride, performance, fuel consumption etc. Yung mga add ons sa XUV and XUVi, are they worth it? Will welcome comments with all crosswind variants: XT, XTO, XTRM, XUV, XUVi. Thanks!!
    Aug 2003
    your budget?
  3. FrankDrebin Guest
    Magkano na ba ngayon ang price ng 2nd XUVi?
    Aug 2003
    Actually, the office will pay for it but need to justify higher models instead of the basic XT. 2nd hand lang dahil sa economic conditions natin ngayon, kailangan justifiable ang mga gastos. Budget? Di ba depending on year and model type, it can go from 600-800K?
    800K
    yung bayaw ko may 2002 Crosswind XUV up for sale
    color blue
    720K
    pm me if ur interested.
    meron kami dito sa office, XUV auto-tranny... unit ng daughter ng boss ko. less than a year old yata.
    going back to the question... between XTO and XTRM, XUV, ... i'd say i'll go for the XTO. not because I'm biased but because mas mura maintenance in the long run. mas maliit gulong ng XTO - hence cheaper tyres to replace, sleeker, less abubot (no body claddings that will get damaged etc pag nabangga, simpler repainting job.) , less body roll on cornering at high speeds ... yun e based sa sinabi mo na office vehicle yan. mas malaki chance na ma-approve kung XTO. fuel consumption and performance, halos pareho lang yan... pero wag naman XT, okey din kasi yung power amenities ng XTO (power windows, side mirrors, door locks, rear wiper - very useful during rainy season). pero kung payag sila na XUVi --- XUVi ka na .... yung lang, it'll be quite hard to justify why you need the other amenities like karaoeke system, VCD system etc. unless sabihin mo na kailangang mo ng onboard entertainment for your guest during driving hehehehe :D
    Aug 2003
    thanks rsnald. nakasakay na ako sa xto. medyo maalbog ang ride compared to the highlander series, tama ba ang observation ko? How about xtrm? lift up without the karaoke features? would the xtrm or xuv ride be stiffer or same as the xto? yung xto uses a 65 series tire. can we fit it with 70 series and will this improve the ride, thicker side wall thus better shock absorption by the tires?
    Originally posted by altec
    thanks rsnald. nakasakay na ako sa xto. medyo maalbog ang ride compared to the highlander series, tama ba ang observation ko?...
    - cant answer this. matagal nako di nakasakay ng orig hilander series. most of the time passenger lang ako sa hilander.
    si master boknoyXTRMXUVi makakasagot nyan. his handle says it all... he has both an XTRM (d orig XTRM hilander) and the new XUVi
    ...How about xtrm? lift up without the karaoke features? would the xtrm or xuv ride be stiffer or same as the xto?
    - again, si master boknoy makakasagot nyan.
    ...yung xto uses a 65 series tire. can we fit it with 70 series and will this improve the ride, thicker side wall thus better shock absorption by the tires?
    - I think one of our fellow forumer uses 70 series -- si dieselNUbi yata... si master xwind yan ang plano nya or baka nagawa na nya
    -install a 70 series tyre on his XTO
    [SIZE=1]Edited: Inayos ko lang po yung quotes. -Ungas[/SIZE]
    Aug 2003
    sleek ang XTO it can even outrun an XUV...and makikipag sabayan sa VX80 wag lang sa rectahan hehe...
    they run daw like cars... sabi ng mga isuzu pips 2nd hand XTO ang hanap nila...madami daw naghahanap
    *rsnald di po ako master
    until now di ko pa na complete yun budget for 70 series pero dami na ko nakita xto na naka 215/70 r15
    Gud am...
    Sir Altec ito po ang answer ko diyan...
    Kahit ano po Model na Xwind ang kunin niyo LAhat po yaan ay matalbog nagkakatalo lang sila sa Height Clearance, Ammenities and ek ek.. same engine same body (siyempre yun iba may cladding) more on ammenities lang talaga... pero siyempre Big tires and High Clearnce.. makes XTRM, XUV, XUVi more commanding... wala po pinagkaiba yan tatlo na yan.. pwera sa ammenities
    Sa Ride....
    kung gusto mo nang Car Like ang takbo... Go for XL, XT, XTO kasi ang gulo nila is small there FGR is 4.1 while the FGR nang XTRM pataas eh nasa 4.3 same as the Trooper.
    Yup mas magaan ang mababang kotse...
    kung sa Highlander na series I got the Top end model mas feel ko ang takbo nang XTRM ko kasi twerkado na ang engine ko...
    Pero still it is up to u.. notice I don't recommend any.. kasi nasa sa iyo yun I gave only the facts and figures... pero it is up to u.
    HTH
    Aug 2003
    nakabili na ako ng xto manual 01 model. Ok naman, maalaga ang may ari. Tanong ko lang, is it normal for the engine operating temperature at 1/2 level? Kasi yung fuego ko with the same engine is at 1/3 level lang.
    wow congrats.....ilan kms mo nakuha yun xto mo?
    yup always ganyan lang yan temp 1/2 then rpm is 750
    Aug 2003
    49+Kms, casa maintained every 5K, naka change oil na nga when I got it kasi sked na siya for renewal, tapos na rin ang emission test. Yun lang nga, I have to spend for the insurance, plus kalbo na ang orig yoko tires niya. Xwind, nakita ko yung pics ng ride mo with the new 215/70 tires. Ano yung specific tire na kinabit mo? I looked at both dunlop 501 and the sp70, yung sp70 4 ply, ang 501 mas radical ang tread pattern niya at mas mahal. Ok lang pareho? Parang sabi mo na sumasabit sa mud guard kaya may ginawa ka para di sumabit? Papano kung kargado? May nagsabi daw yung harap naka 205/70 from 205/65 pagkargado sumasabit, pero ang likod naka 215/70. Better if all 4 tires are the same di ba?
    mga master, me tanong lang po, medyo curious lang....
    yung gear ratio ba nang Crosswind A/T variants eh magkaiba pa sa XUV series at XTO series?
    Kasi di ba mas malaki ang gulong nang XUV series kesa XTO series....pinag-iba pa ba ang gear ratio nito para ma-compensate yung differences or parehas lang?
    Kung parehas lang papano nyo na-compensate? papano yung odometer readings, di ba mechanical pa rin ang system nyan?
    Kung magkaiba naman ang gear ratio, ano yung sa XTO, yung XUV kasi around 5.xxx ang final ratio di ba?
    Yan lang po ang aking katanungan....sabi kasi nung iba parang mas matulin daw ang XTO A/T kese XUV A/T sa rektahan, kaya napaisip tuloy ako...kasi regardless nang weight factor kung parehas ang gear ratio, in paper iisa lang ang top speed nyan....tama po ba?
    We also just got recently an '02 XTO a/t with 35K on the odo. Tiga-Alabang Hills yung owner and complete records niya and maganda pa yung condition (no bumps or scratches but i had some small door dings).
    First impression was that it needs a heavy foot to get a-goin from stop due to its being a diesel matic but its happy running at speeds of 80-100kph. I find the handling on the low side though due to the excess of body roll and understeer when i compare it to my pick-up (maybe wider tires and gas shocks will help increase the stability and cornering capabilities a bit). I also wish it had cup holders... :P
    The orig Yok tires are still good but we plan to change it in a few months to 215/65 or 205/70 R15 tires (Probably put Dunlop LeMans RV or LM702s).
    I've also added new headlight bulbs (90/100W) with relays... gotta change the tint though (pag may budget).
    bump!!
    ...any isuzu master out there to answer my curious question? master buknoy? master RSnald?
    sir 5speed
    ito po eh kng tama ha.. siyempre the other masters will comment
    XL, XT, XTO - 4.1
    xtrm, XUV, XUVi - 4.3
    XUV A/T XUVi A/T - 5.102
    Vinj,
    mabigat ba ang apak.. pagaanin natin.. pag nagkita tayo sa EB heheheeheh
    ser boknoyxtrm...salamat po...
    eh papano po yung XTO na A/T, 4.1 din po ba o 5.102 din yung final ratio? doon po kasi ako curious since parang malaki na ang diperensya nang circumrerence nang gulong nang XTO at XUV variants hence kaya magkaiba sila sa manual tranny pagdating sa final ratio...
    sori po master...medyo makulit nang konti....napaisip lang po....hehehe
    so tama nga kwento yung nasakyan kong megataxi nung umuwi ako last month...sabi nila they can outrun a manual tranny XUVi w/ their crosswind XT's kahit daw may 2 pa silang extrang pasahero kumpara don sa XUVi to compensate for the weight of the claddings and other accessories....hehehee
    so napaisip tuloy ako...how about the A/T variant? will the case be the same??
    sana me makatulong....sori po ala lang magawa ngayon...hehehee for the benefit na rin nang mga me crosswind dito...hehehe
Crosswind Models: Which is better
