Results 11 to 20 of 42
June 7th, 2004 09:32 AM #11
Gud am...
Sir Altec ito po ang answer ko diyan...
Kahit ano po Model na Xwind ang kunin niyo LAhat po yaan ay matalbog nagkakatalo lang sila sa Height Clearance, Ammenities and ek ek.. same engine same body (siyempre yun iba may cladding) more on ammenities lang talaga... pero siyempre Big tires and High Clearnce.. makes XTRM, XUV, XUVi more commanding... wala po pinagkaiba yan tatlo na yan.. pwera sa ammenities
Sa Ride....
kung gusto mo nang Car Like ang takbo... Go for XL, XT, XTO kasi ang gulo nila is small there FGR is 4.1 while the FGR nang XTRM pataas eh nasa 4.3 same as the Trooper.
Yup mas magaan ang mababang kotse...
kung sa Highlander na series I got the Top end model mas feel ko ang takbo nang XTRM ko kasi twerkado na ang engine ko...
Pero still it is up to u.. notice I don't recommend any.. kasi nasa sa iyo yun I gave only the facts and figures... pero it is up to u.
HTH
Tsikot Member Rank 3
- Aug 2003
- 1,251
July 25th, 2004 03:48 PM #12nakabili na ako ng xto manual 01 model. Ok naman, maalaga ang may ari. Tanong ko lang, is it normal for the engine operating temperature at 1/2 level? Kasi yung fuego ko with the same engine is at 1/3 level lang.
July 26th, 2004 09:40 AM #13
wow congrats.....ilan kms mo nakuha yun xto mo?
yup always ganyan lang yan temp 1/2 then rpm is 750
- Aug 2003
- 1,251
July 26th, 2004 12:15 PM #1449+Kms, casa maintained every 5K, naka change oil na nga when I got it kasi sked na siya for renewal, tapos na rin ang emission test. Yun lang nga, I have to spend for the insurance, plus kalbo na ang orig yoko tires niya. Xwind, nakita ko yung pics ng ride mo with the new 215/70 tires. Ano yung specific tire na kinabit mo? I looked at both dunlop 501 and the sp70, yung sp70 4 ply, ang 501 mas radical ang tread pattern niya at mas mahal. Ok lang pareho? Parang sabi mo na sumasabit sa mud guard kaya may ginawa ka para di sumabit? Papano kung kargado? May nagsabi daw yung harap naka 205/70 from 205/65 pagkargado sumasabit, pero ang likod naka 215/70. Better if all 4 tires are the same di ba?
July 26th, 2004 12:40 PM #15
mga master, me tanong lang po, medyo curious lang....
yung gear ratio ba nang Crosswind A/T variants eh magkaiba pa sa XUV series at XTO series?
Kasi di ba mas malaki ang gulong nang XUV series kesa XTO series....pinag-iba pa ba ang gear ratio nito para ma-compensate yung differences or parehas lang?
Kung parehas lang papano nyo na-compensate? papano yung odometer readings, di ba mechanical pa rin ang system nyan?
Kung magkaiba naman ang gear ratio, ano yung sa XTO, yung XUV kasi around 5.xxx ang final ratio di ba?
Yan lang po ang aking katanungan....sabi kasi nung iba parang mas matulin daw ang XTO A/T kese XUV A/T sa rektahan, kaya napaisip tuloy ako...kasi regardless nang weight factor kung parehas ang gear ratio, in paper iisa lang ang top speed nyan....tama po ba?
July 26th, 2004 12:40 PM #16
July 26th, 2004 01:17 PM #17
We also just got recently an '02 XTO a/t with 35K on the odo. Tiga-Alabang Hills yung owner and complete records niya and maganda pa yung condition (no bumps or scratches but i had some small door dings).
First impression was that it needs a heavy foot to get a-goin from stop due to its being a diesel matic but its happy running at speeds of 80-100kph. I find the handling on the low side though due to the excess of body roll and understeer when i compare it to my pick-up (maybe wider tires and gas shocks will help increase the stability and cornering capabilities a bit). I also wish it had cup holders... :P
The orig Yok tires are still good but we plan to change it in a few months to 215/65 or 205/70 R15 tires (Probably put Dunlop LeMans RV or LM702s).
I've also added new headlight bulbs (90/100W) with relays... gotta change the tint though (pag may budget).
July 26th, 2004 05:33 PM #18
bump!!
...any isuzu master out there to answer my curious question? master buknoy? master RSnald?
July 26th, 2004 05:54 PM #19
sir 5speed
ito po eh kng tama ha.. siyempre the other masters will comment
XL, XT, XTO - 4.1
xtrm, XUV, XUVi - 4.3
XUV A/T XUVi A/T - 5.102
Vinj,
mabigat ba ang apak.. pagaanin natin.. pag nagkita tayo sa EB heheheeheh
July 26th, 2004 06:12 PM #20
ser boknoyxtrm...salamat po...
eh papano po yung XTO na A/T, 4.1 din po ba o 5.102 din yung final ratio? doon po kasi ako curious since parang malaki na ang diperensya nang circumrerence nang gulong nang XTO at XUV variants hence kaya magkaiba sila sa manual tranny pagdating sa final ratio...
sori po master...medyo makulit nang konti....napaisip lang po....hehehe
so tama nga kwento yung nasakyan kong megataxi nung umuwi ako last month...sabi nila they can outrun a manual tranny XUVi w/ their crosswind XT's kahit daw may 2 pa silang extrang pasahero kumpara don sa XUVi to compensate for the weight of the claddings and other accessories....hehehee
so napaisip tuloy ako...how about the A/T variant? will the case be the same??
sana me makatulong....sori po ala lang magawa ngayon...hehehee for the benefit na rin nang mga me crosswind dito...hehehe
I hope they improve the interior a bit. The current is IMHO low-rent for the price.
2025 Nissan Kicks
