Results 11 to 16 of 16
August 10th, 2009 10:28 AM #11
- Aug 2009
- 149
August 10th, 2009 10:35 AM #12hehehe choice of bumpy or FC....
may parts ba na affected or masisira if matagtag or mataas pressure ng gulong...upto what pressure ba kaya ng gulong ng sportivo?
August 10th, 2009 11:55 AM #13
From my point of view, wala namang parts na masisira that can directly be attributed to high tire pressure --- talagang matagtag lang. (yung utak siguro nung sakay nung Crosswind ang makakalog at masisira... hehehe!)
As to the "maximum" tire pressure the tire could take, kaya siguro kahit na 50psi but the question is; "Why would you want to do that?" I would suggest that you stick to the recommended tire pressure as stated in the notuice located at the B-Pillar. Should you want to add more as recommended, not so much.
August 10th, 2009 02:01 PM #14
^^^ thank's bro, would greatly consider it.
A little bit OT; with a tire pressure of front 30psi / rear 34 psi compared to my present front 34psi / rear 38psi - can i say the lesser psi would grip the road more than a higher psi ? And cons is just the fuel consumption, how about speed ?
August 10th, 2009 02:19 PM #15
A little bit OT; with a tire pressure of front 30psi / rear 34 psi compared to my present front 34psi / rear 38psi - can i say the lesser psi would grip the road more than a higher psi? And cons is just the fuel consumption. Logically speaking --- yes. Having less air in the tire would "flatten" the tire; such would result to more rubber in contact with the ground.
how about speed? Technically, less air in tire should affect the speed too -- since less air in tire would make the tire "heavier". But it'll be quite difficult to really notice the difference.
- Aug 2009
- 149
August 10th, 2009 02:23 PM #16
Somewhat expected from a rushed car from a first time carmaker
Xiaomi E-Car
