Results 11 to 20 of 24
- 106
June 17th, 2004 06:57 AM #11Thanks guys. I'll compare the pirelli and bridgestone na lang and check kung alin ang mas ok. Dito po sa pinas ko ginagamit yun trooper. Nakita ko lang po sa makati yun bridgestone winter tires at medyo nagandahan lang ako duon sa porma niya.
Tsikot Member Rank 3
- Dec 2002
- 636
June 17th, 2004 06:58 AM #12Trooper's stock tires are indeed 245/70R16 so using wider/larger tires will alter gear ratios, speedometer accuracy and fuel efficiency.
- 10,620
June 17th, 2004 09:10 AM #13im using dunlop at2 (245/70/16 or 29 inches diameter )on my trooper, ok naman ang performance sa on road pero so-so sa trail,
and contemplating of upsizing the tires to 265/75/16 (31-32 inches)
imho kaya pa naman gearing basta wag ka lang lalagpas sa 33 inches
Tsikot Member Rank 5
- 3,144
June 17th, 2004 09:35 AM #14Am using dunlop at2 245/70 R16.
Wala kasing bridgestone deuler AT at the same size, yong pinakamalapit ay 265/70 R16
- 10,620
- 3,144
June 17th, 2004 11:16 AM #16pansin ko nga, parang pudpud na dunlop samantalang dalawang beses ko pa lang tinakbo sa mga broken pavements of samar.
on the other hand, worry ko sa 265 ay yong duming ikakalat sa body (labas kaya ang tire sa fender?)
- 10,620
June 17th, 2004 11:54 AM #17sakto lang
265mm = 10.5 inches
nung nilagay ko yung 31x10.5x15 mud tires ng strada sa trooper ay ok lang.
mas lalabas yan kapag yung rims mo ay 8 inches and lapad
factory spec is 16x7 so ayos lang
June 17th, 2004 12:05 PM #18
redhorse: me fender flare naman yung white horse mo di ba. yung sakin kc wala pero konti lang labas. Sakto cguro pag nilagyan ko sakin. (di pa stock rim ko).
Kimps: Di ako nakapunta sa capalangan last time nung txt kita. Kailangan ko balik kagad ofc. Kung mapasyal ka capalangan, pwede b pakikuha yung cell ng nakitaan mo ng flares.TIA.
- 10,620
June 17th, 2004 12:22 PM #19yup ako rin wala pang fender flares pero ok na ang dating ng 10.5 or 265mm lapad.
niwde11,
pare mas ok kung fiberglass kasi yung sa capalangan kulang kulang, ang mahal pa aabutin tapos warped pa minsan. (1 big fender costs 1K eh apat yun tapos yung pang bumperettes and mud guards pa
yung sa fiberglass (sa DAU) 6500 all in pati yung mga bumperettes, mud guards,
June 17th, 2004 12:28 PM #20
tnx kimps. nagdadalawang isip din kasi ako kasi maganda na rin naman kahit wala. Madumi lang talaga body pag umuulan saka bubutasin pa pag nilagyan. Just in case, i'll txt you pag decided na ko.
My rough guess is that the outgoing 2nd gen Innova is still in high demand and is cannibalizing the...
