Results 31 to 40 of 49
- Dec 2002
- 85
March 8th, 2004 02:09 AM #33pk, I had kyb monomax on all fours of my pajero... the ride was a bit spine bashing (very harsh) but stability/ control on roads and doing fast corners were its high scores. I could do almost twice the speed on corners than the oem shocks. but after 2 months I changed the rear to rancho bec the ride quality was really irritating. I think I now have a very good combination.
March 9th, 2004 05:40 PM #35
Yup! Gas-A-Just shocks are very nice in deed. It is kinda stiff but it works well in light to moderate trailing. Just got one installed on my Vitara. If you consider cheap and alternative shocks for your vehicle, try one of this. A surplus KYB Gas-A-Just shocks will cost you around P8000 to P900 each sa Banawe. Location is beside Jamson Auto supply. You can also buy different 1" coil spring spacers there for added lift to your vehicle. P150 labor costs for the installation of Coilspacers for both rear end. Coil spacer costs around P125/each. Look for Jun Aclan Batangeno. I hope this helps!
March 10th, 2004 09:18 AM #36
Got to install the shocks and they had a big difference over the OEMs (well my OEMs are shot already though).... its also stiffer then the other KYB gas shocks available locally (forgot the model)...
Tsikot Member Rank 3
- Dec 2002
- 636
March 10th, 2004 06:35 PM #37vinj,
What difference did you notice with gas a just?
Do you recommend them on pickups based on your experience?
March 11th, 2004 09:59 AM #38
Since my stock shocks were very soft (KYB Fluids), the ride firmness and stability was a big improvement as i dont bottom out any more when i drive on uneven roadways... However, some peeps might still find it stiff for their taste if they're used to driving cars.
I also reversed the rear helper spring of my pick-up so the stiffer shock does help keep/compensate the rear load should i load up but the perpetual jarring up-and-down motion that accompanied the Frontier ever since day one, even on smooth roads and when i hit bumps are now gone.
I still have to use them on a long drive to get the more feedback though.... but i'm happy and its worth the PPP
March 11th, 2004 01:15 PM #39
It is really stiff when it comes to comfort of ride BUT it compensates by giving a little lift, sturdiness and durability. I think it will be perfect for Pickups and medium SUV's. Try it! The cost wont bite you.
March 11th, 2004 01:25 PM #40
I would just like to clarify one point, shock absorbers do not provide any lift from suspensions at all. Maybe you'd notice a little height adjustment after replacing them. But once the suspension has settled over time, it will revert back to its original height.
Puwede siguro gapang ang wire sa space ng rear hatch lifter/struts papunta sa rear bumper, tapos...
