Page 41 of 73 FirstFirst ... 3137383940414243444551 ... LastLast
Results 801 to 820 of 1445
    Apr 2008
    #801
    Quote Originally Posted by s_quilicot View Post
    Yung sa akin, sa existing bracket lang naka kabit. swak na swak. Mas maganda ang beam pattern and clear ang lens nito.
    It cost me AFAIR 3.5k sa maspro banawe including installation.
    OK to ah. Meron ba sila yung foglight switch ng Trooper natin? And yung 3500 is 2 pcs na or per piece?
    Mar 2004
    #802
    Quote Originally Posted by goldrat View Post
    thanks Goldrat. will give feedbacks when i try to diagnose.
    #803
    Quote Originally Posted by GTi View Post
    yung sa akin may switch na talaga na OEM. Nag upgrade lang ako.
    Pair napo yung 3.5k. may nabibili namang wiring harness for h3 na may push button switch with LED indicator for AFAIR 700php.
    Apr 2008
    #804
    3500k dalawang fogs na? Mura ah! Dun ba rin sa Maspro merong mga Isuzu parts available like the OEM foglamp switch? Yung binili niyo ba na fogs yung dilaw o yung puti?
    #805
    Malapit lang naman ang walco for OEM parts. 1 minute walk lang.
    Yung clear ang binili ko with 4300k HID.
    Apr 2008
    #806
    Ah, sorry kasi medyo noob ako pagdating sa mga Banawe shops. I never had the occasion prowl around the area even if we do live near Banawe. So I can buy the OEM switch from Walco and the fogs from Maspro and have workers from both stores working on the car at the same time? And do they sell Philips Xtremepower or any similar headlight bulb there? The headlights' performance is just too bad! Any idea about the cost of two of those?
    Jul 2003
    #807
    Yung Skyroof na walang fogs.
    2003 model hehehe.
    Ang nakaka-inis lang, tuwing makaka-bili ng kapalit, may mawawala agad
    Nagpa-fabricate na ako ng edge sa passenger side, nawala naman yung sa driver side.
    Meron bang step board na pwedeng ipalit dito?
    SG magkano ROOFRAIL mo? Sa casa mo ba binili?
    #808
    Quote Originally Posted by nap123 View Post
    Sa Southern Motors Davao galing yung Roof rail kasi doon binili yung Trooper. It was 8 years ago, di ko na maalala yung price. Di pa ata ako nakakapag-drive noon
    May 2008
    #809
    yep 2005 skyroof.
    Get the clear one and put 4300k HID on it.
    magandang project ito.. sana lang meron na din clear lens ang headlight ko..
    Jul 2003
    #810
    Quote Originally Posted by iong11 View Post
    Hahaha si Garyq contakin mo regarding clear lens meron na sya for model 1998-up na headlight. Now he is doing the 1992-1997 headlight clear lens kaya maging complete na yung molde ng clear lens ng trooper. Dito lang yan sa pinas
    Apr 2008
    #811
    Ngayon may magandang meaning na ang "only in the Philippines"! Mahal ang projector type eh... Does he happen to also do ordinary multireflector headlights as well?
    Apr 2008
    #812
    My dad has a worry about the Hella Comet 450 foglights. He was saying that since our area is very flood-prone (and water levels can get very high), and the foglights are located down below, wouldn't water easily seep into the submerged foglights? Is it appropriately sealed enough so as to ensure that this would not happen?
    Jul 2003
    #813
    Malas natin walang clear lens ang trooper kaya there is no option na ipaprojector mo with stock headlight. may mura naman projector sana kung clear lens yung headlight natin yung bolt on projector na china is another alternative.
    Apr 2008
    #814
    What I meant is kung gumagawa ba siya ng di-projector type na clear type headlights? Yung ordinary multireflector lang, for our Trooper? I suppose that will cost much less kung sakali?
    And what do you think about the Hella fogs? Would water go in? That is the only major worry that we have, living in a flood-prone area. Kasi kapag madaling pasukan ng tubig, huwag nalang daw and just live with better headlamp bulbs.
    Jul 2003
    #815
    sa unang tanong better ask garyq directly he is very nice person madaling kausap.
    regarding Hella fogs the best thing you can do iresealant mo yung paligid ng fog use a good sealant, sa tingin ko hindi sayang yung fog kasi hindi naman araw araw nilulusong mo sa baha since need morin talaga ng backup light you can use the fog incase mapundi isang ilaw ng headlight mo.
    #816
    Ipa reseal mo nalang with clear silicone. Ok naman sa akin. Dumaan nako sa baha na umabot yung wave hanggang sa may grills, no prob naman.
    Apr 2008
    #817
    Hehe... Nahiya akong magtanong sa kanya kasi malabo naman na magpapagawa ako eh. Its just that before, I saw a Hilander SLX with multireflector headlights and I got curious.
    About dun sa pagsea-seal, pwede kaya ipaseal agad after installation? Mga magkano kaya ang added cost? Kapag sineal na, paano kung papalit na ng bulbs? Saan siya tinatanggal? I'm very interested with the foglights kasi it seems to be one of the few less costly ways of improving visibility with this car. Yun nga lang, I see lots of cars with either water inside their fogs or with rusty fogs...
    May 2008
    #818
    sir pwede kaya lens lang ipagawa? or set talaga na paretrofit HID?
    balak ko kabitan na lang ng bolt on projector lamps na china eh..
    thanks..
    #819
    Hi to all,
    Ask ko lang po, tlaga po bang iba iba ng brand ang cooling sytem ng trooper? Kaya ko po kasi na tanong, due na for replacement ung AC Compressor ng 2003 trooper ng tito ko, upon inspection ng technician SANDEN ang nakalagay na AC compressor. tlaga po bang ito ang stock AC Compressor ng mga 2003 na trooper? kasi ung isang trooper naman po ng barkada ko, (2000mdl MT 4x4 na 4JX1) same engine with my unlce's trooper ZEXEL ang nakalagay. Nag ikot ikot na din po ako sa mga surplusan ZEXEL din ang nakalagay. And isang problem pa, mag kaiba din po ng bracket ang 2003 trooper w/ SANDEN AC sa mga surplus na 4JX1. Ano pa po kaya ang option namin?
    Feb 2005
    #820
    Quote Originally Posted by batosai View Post
    Hi to all,
    Trooper was using Zexel until sometime mid-2000. Afterwhich, the A/C system was localized to SANDEN.
Isuzu Trooper discussion
