Pag ipapa-retro yung fogs, wag nalang.
Headlights nalang. Mas malaki ang coverage![]()
From wikipedia. :D
An oil catch can is used in turbo applications, or high-performance race applications where excessive blow-by (leakage past the piston rings) of air and fuel vapor occurs. This creates a positive pressure in the crankcase. Engine manufactures have placed a valve on the engine block which releases this pressure. This valve is known as a PCV (Positive Crankcase Ventilation) valve. During engine operation, blow-by gases, as well as oil mist from the rotating components of the engine, pass through the PCV valve and are routed back into the intake for the engine to burn off. However, some of the oil mist and other products settle along the engine intake and over time form a "gunk." The oil catch can collects the oil mist and condenses the fuel vapors while allowing "cleaner" gases to be passed back into the intake. Typically the blow-by gasses are passed through a wire mesh, which give the vapor droplets something to adhere to. Since the oil catch cans condense the vapor portion of the gasses, they will need to be drained periodically of all the oil, fuel and other contaminants.
Read more: http://wiki.answers.com/Q/What_is_an...#ixzz1E0a93VRR
mga sir bka sakali meron kau nito or may alam kau kung san meron.. thanks!
Yung OE na fog for trooper 15K, sa walco 4.5K each sa jayson same din ata ng sa casa ang price. Try mo rin yung pang hilander na foglight yun ang ang ginawa ng isang tsikoter dito yung ngalan some diy sa bracket. Iba parin yung OE na foglight sakto yung bracket niya. Yung sakin retro ni garyq mura parin compare sa OE na foglight kasi materiales bought from ebay.com medyo labor cost lang ginastos ko kaya pinaretro ko na![]()
Huwag na DIY, kakatamad eh, tapos baka masiraan pa.Bat mas mura yung sa Walco? Sakto rin yan sa bracket noh? Nasaan ba yung Walco? Care to provide some directions? I'm not very familiar with the Banawe shops eh. Is it at Banawe nga ba?
About dun sa Hilander, I've always thought they were the same. Di ba pareho lang ang bumper ng Trooper at yun ng Hilander XTRM?
http://www.itocuk.co.uk/forums/viewtopic.php?t=23253 hope this helps.
if m not mistaken skyroof po ang ride nyo sir.? parehas po ba ng bracket sa bumper ang skyroof and bighorn? i purchased a surplus bumpers w/ fogs OE for subic look trooper..
maganda nga ito kasi clear na ang lens.. cgurado maganda ang output, lalo cguro kung hid pa..
thanks for the info sir.. nakita ko nga pla sample pics. nito, meron din color yellow.. much greater porma for jdm look..
Skyroof 2005 yung kay SQ.
May stock brackets na for the fogs.
Ang problema ko eh.. Yung akin wala pahaha
Yung Skyroof na walang fogs.
2003 model hehehe.
Ang nakaka-inis lang, tuwing makaka-bili ng kapalit, may mawawala agad
Nagpa-fabricate na ako ng edge sa passenger side, nawala naman yung sa driver side.
Meron bang step board na pwedeng ipalit dito?
