Results 371 to 380 of 537
November 4th, 2018 03:13 PM #371
- Nov 2017
- 1,748
November 4th, 2018 06:50 PM #372
November 4th, 2018 06:54 PM #373
November 5th, 2018 11:49 AM #374
Bro, while peak torque is the same, the dual turbo YS23 has a wider torque band vs the single turbo YD25. And 10Kg lighter. Would've been a lot lighter if it had a single turbo. Performance-wise it should be better. Botchi of Topgear Ph has driven the NP300 with the YS23 and did like it better. Question is how much better? The 190 ps YD25 in the Terra is more than enough. Pretty good power at both low and high rpm (for a diesel). While torque peaks at a single point (2000 rpm), it doesn't feel like it falls off much across the rev range.
- May 2015
- 146
November 12th, 2018 01:08 AM #375Bakit naman yung innova namin. 2.5 and 102hp 200NM we tried already loading up to 9 midsize adults (including the driver and ako yon) papuntang Camsur. Di ko ramdam na kulang sa lakas. I also drove it sa Baguio 2x magkaibang daan each 1 marcos and another one sa kennon. Di naman ramdam na "underpowered".
Eh ano pa yang 1.9 na 150hp and 350NM? Pinoy talaga hahaha. Daming gusto.
Sent from my Redmi Note 5 using Tapatalk
- 52,731
November 12th, 2018 01:12 AM #376
November 12th, 2018 07:25 AM #377
- Jun 2016
- 39
November 27th, 2018 07:29 PM #378Temp din kami sa LSA 1.9
kailangan ko kc matipid sa diesel,.
pero konti na lang, laki ng discount sa 3.0
sa mga naka 3.0 LSA
ilan FC nyu Highway Driving?
mostly kasi once a month province - ncr
biyahe ko, everyday 40-120 kms depende
bahay to work lang,.
Gamit ko pala
mitsubishi adventure gls 2013
171,000+ kms na FC=10-12km/l
November 27th, 2018 07:36 PM #379
- Jun 2016
- 39
November 27th, 2018 10:00 PM #380sir,
ibig mo ba sabihin
matakaw din MUX 3.0 LSA?
di ba sya mas matipid kaysa advi ko?
sa mga naka 1.9 naiakyat nyu na ba
Baguio? esing easy lang ba?
Viscaya Santa Fe N.E. easy lang ba iovertake sa mga busses, trailer trucks?
kahit loaded kayo w/passenger..
sa advi ko kc 2nd/3rd gear 2.5k-3.5 rpm
para maka overtake sa mga trailer paakyat
santa fe road,.
high idle RPM at engine start
