Page 1 of 2 12 LastLast
Results 1 to 10 of 640
    Quote Originally Posted by Benzmizer View Post
    I'd say it'll be a challenge.
    Nawala yung blinking Blue Led sa dashboard ko di ko alam kung napundi ba ung LED light or may problem yung alarm system ko, any idea how to check this?
    Feb 2005
    Quote Originally Posted by TholitzReloaded View Post
    Simple, go out of the vehicle. "ARM the vehicle. manually open the door using your vehicle keys. If the alarm goes off, it's likely a busted LED/faulty wiring supplying electricity to the LED. If the alarm does not go off, your alarm is likely at fault.
    Eitherway, walang isang problemang di nagagawa. Bring the unit to a CASA and the supplier of the alarm would have technicians who can check your alarm. If no mods were done in connection to the alarm and the vehicle is still under warranty, you might even have the alarm replaced/fixed for free!
    Jun 2010
    Good pm, have a plan to change my tires ( Goodyear Fortera ) to mechelin or maxxis, ask ko lang if pwede mag-add sa series...mine is 235/70R/15 then gusto ko ilagay ay 235/75R/15, is it possible...for my computation is mag-add ang tire diameter for almost an inch, so it means less speed...need advice po mga bro...thanks in advance
    Yep ok lang iyan.
    So instead of 70% of 235 yung sidewall height, 75% na. 5% isnt' that much. Just a few mm.
    Use an online tire calculator to help you
    Jun 2010
    Yep ok lang iyan.
    based on my calculation, my old tire diameter (235/70R/15) has a total diametr of 27.952756" then kung palitan ko ng ( 235/75R/15) now has a total of 28.877953", the difference is 0.925197"...so it means it is still allowed on a 3% additional ( 0.8385827 ) to your old tire dimension without affecting your vehicle system to compute in regards of distance...correct me if im wrong
    Jun 2010
    Yep ok lang iyan.
    based on my calculation, my old tire diameter (235/70R/15) has a total diametr of 27.952756" then kung palitan ko ng ( 235/75R/15) now has a total of 28.877953", the difference is 0.925197"...so it means it is still allowed on a 3% additional ( 0.8385827" ) to your old tire dimension without affecting your vehicle system to compute in regards of distance...correct me if im wrong
    Any change in tire diameter (even normal wear) can affect your odometer to some extent. But diameter changes of less than 10% will not significantly affect other vehicle systems.
    Jun 2010
    im almost using this xuv crosswind A/T for a month, 30000 km in odo, my question is the fuel consumption, i got only 7 to 8 km/liter, mix n po yon ang city driving and hatawan, im living in lipa city batangas...regular nman ang pms nito, any suggestion..
    Aug 2004
    Quote Originally Posted by xwind_mariner View Post
    How bad is the traffic? Our old XTO AT also does around 8 km/l in the city.
    If you drive more conservatively, go with the flow and keep the revs low, it should improve a little, but don't expect the same 10-12 km/l that us MT guys are getting in traffic.
    Jun 2010
    actually, it never to say it was a traffic inside here in lipa city, just stop and go, maximum of 40km, for most of time, im using this xuv to market and back to my house everyday, about 13km back and forth then once a week went to my farm, about 70km in one way, and goes to there, i just only made an average of 50km/hr..only few minutes to enjoy the speed of 80 to 90 km/hr. i usually make a full tank every week, reset the trip meter, then in almost more or less half on the fuel gauge, ive made to full tank again and compute the consumption, distance made according to trip meter and liter of diesel i filled up.
Isuzu Crosswind XUV/XUVi Owners
