Results 3,371 to 3,380 of 3710
- Mar 2016
- 9
March 13th, 2016 06:50 PM #3371Sir, just saw this question. Newbie sa Tsikot but can give u good info. Pag nag check tayo ng coolant, radiator at reservoir parehas I chk. Kung kelangan dagdagan ang radiator, do it, yung reservoir dapat ay nsa gitna lng ng min at max ang level. Hindi pinupuno yan. When the engine is hot, the water in radiator gets pressurized and some of the water in the form of "steam" escapes thru the radiator cap and passes thru the hose papuntang reservoir. Then , when you stop your engine, the radiator gets cooled and creates a vacuum sa bandang itaas, and the water sa reservoir is sucked back to the radiator. Actually may isang hose sa reservoir na expose to the atmosphere, that is to "push" the water into the radiator when the vacuum exist. So lagging nsa gitna lang ang level ng reservoir.
- Aug 2014
- 73
March 17th, 2016 03:59 AM #3372thank you sir sa magandang explaination. sabi kasi ng iba di naman daw nababawasan ang coolant sa radiator at lagi lang daw syang puno. kaya ang gawa ko sa reserve lang ako nag babase kung need dagdagan. actually simula ng nakuha ko sa firsth owner yung crosswind xto ko hindi nawawala sa tamang level yung coolant sa reserve. pero gaya ng sabi mo need din icheck yung radiator mismo. nag worry din ako baka kulang na yung coolant ko sa radiator mismo kasi never kung binuksan lagi lang ako sa reserve natingin hehe. bukas na bukas check ko agad yung radiator ko hehe.. maraming maraming salamat sa info sir salamat sa time din sa pag turo mo sakin salamat
- Jul 2015
- 7
March 20th, 2016 03:37 PM #3373Mga sir/ isuzu owners, pa educate please on tire rotation: tuwing kailan po ba ginagawa at kung paano? TIA
- Jun 2010
- 321
March 20th, 2016 06:01 PM #3374every 10k km or every other oil change mo http://www.tirerack.com/images/tires...otation_fg.jpg
- Mar 2016
- 1
March 23rd, 2016 02:15 PM #3375Ask ko lang din baka masagot nyo problema ng isuzu wizard ko 4jx1 engine. Hirap mag accelerate pero pag tumakbo na ok na, pero pag huminto hirap ulit mag accelerate.
March 28th, 2016 08:23 AM #3376
Pwede pong mag tanong sa bagong 2016 model ng Crosswind XT at XL?
Yun po bang aircon vent sa pagitan ng second row at back space eh blower lang? (parang may nabasa po kasi ako dati) or may second aircon na pampalamig sa likod?
Salamat po
- Apr 2010
- 742
March 28th, 2016 09:23 AM #3377
March 29th, 2016 05:32 AM #3378
Salamat po sa reply...
May nagpa lift na ba sa iyo dito ng Crosswind Xt or Xl? Gaano kataas po?
- Jun 2015
- 204
VinFast VF 3
