Results 2,871 to 2,880 of 3710
- Nov 2008
- 14
September 13th, 2014 11:06 AM #2871hi all! magkanu po kaya corner lamps for 2004 crosswind?
nakita ko na lang na basag pala yung sa passenger side ng akin.
saan kaya makakabil;i ditto sa batangas-laguna area?
- Sep 2014
- 34
September 14th, 2014 09:57 PM #2873
- Sep 2014
- 34
September 14th, 2014 10:54 PM #2874Nope. At least its possible.
How common is the ignition fuse and fuel pump fuse on a crosswind?
I reckon if its not too common then removing it will act like an immobilizer.
Edit:
I looked up how to install one on an old car and it seems easy enough if you know what your doing. HOWEVER, if your car is NEW it will void your warranty as it involves a lot of wire splicing, drilling, etc.
- Nov 2013
- 14
September 18th, 2014 10:40 AM #2875Good morning, andito ko ngayun s isuzu commonwealth, change oil 70k+ odo reading, anu mga kelangan ko ipa check and kelangan ko ba kunin yung mga old filters na papalitan? Salamat
September 18th, 2014 05:38 PM #2876
- Nov 2013
- 14
September 18th, 2014 09:10 PM #2877
September 18th, 2014 09:36 PM #2878
- Mar 2010
- 143
October 2nd, 2014 05:34 PM #2879nagpalit din ako ng ATF. spent some P3k kasi dalawang beses. yung first time nung nag troubleshooting kasi parang sira turbo (walang boost). mabuti magaling mag isolate mechanic ng Zxl calibration at yun nakaligtas ako sa potential P30k expense (Injector or Pump, or Turbo).
malaki difference sa hatak ng napalitan ATF. Ended up doing it again just after 1day kasi gusto ko na rin palinis yung drain (parang washable filter) at cover/pan. 70k+ mileage.
- Oct 2014
- 4
October 8th, 2014 10:11 PM #2880Good evening, all. I'm new here having just purchased an Isuzu crosswind XT LE.
I have two questions related to the audio / video system. 1) The car was sold as 'reverse camera ready'. What exactly does that mean? I asked about getting a reverse camera installed, and it would cost P16,000, whereas there are cameras available on the market for as little as P1000. Is the wiring all in place just to install a camera?
2) The audio / video system is supposed to have a video out to be able to have a second screen for the back of the car. How does one access that video out? Does one have to remove the stereo and plug into the back of it?
Thanks. Brian
P. S. Sorry if this is not the right place to ask these questions.
VinFast VF 3
