Page 31 of 186 FirstFirst ... 212728293031323334354181131 ... LastLast
Results 601 to 620 of 3710
    Jun 2009
    #601
    Quote Originally Posted by kambal View Post
    Its just as same as most engine treatment oil, it can help minimize engine noise because of its concentration but it will not help boost more speed... wag kn bmili nun mahal un maraming murang engine treatment, mine i used the STP brand.... If you're concern bout added boost and speed, the air intake should be modified just like most modified cars do....
    Unfortunately wla pkong ganung modification na nakikita para sa mga crosswind natin,,, sana magawan nila ng design na ung air filter ay nakalabas na,,, mas mabilis ang pasok ng hangin nun and for sure it will add more speed.....
    With regards to reaching 120++kph, bigyan mo lang ng tamang bwelo bawat gear... mine is xuv 03 model napapatakbo ko pa sya paminsan minsan ng 120++.....
    Good Luck on your trial...
    hi, it is actually possible to fabricate a stainless tube for a cone-type air filter. i will post my pics soon. i have a 2002 xtrm. seats filled with passengers with backload, 120km/h is easy. kaya pang mag 130 kaso ran out of road. a racing-type filter is actually possible for our crosswinds. dagdag lakas din if you use turbo diesel from petron or vpower diesel from shell.
    #602
    Mga pards, may ginawa akong isuzu crosswind page sa facebook, sali kayo, may mga tsikoteers na rin na member doon.
    Nov 2007
    #603
    Quote Originally Posted by ianvios View Post
    I'm actually planning to use my racing filter for our 2008 xwind, pero yun nga wala pa kong nakikitang tubo na kakasya. mahal din kase yung filter nito eh (P600 sa edsa rotonda)
    Jul 2010
    #604
    Quote Originally Posted by oliver1013 View Post
    I'll check it when I get home. Sali ako diyan
    Jun 2009
    #605
    Quote Originally Posted by Fargin View Post
    I got my filter sa Blade Shangrila. P1800 ang kuha. it comes with a stainless tube na. May free Blade sticker pa nga eh. ) you have two kinds of tubes to choose from. choose the long one with a short curve. it was too long so get a metal saw. fits perfectly. i will post my pics tomorrow. very possible DIY.
    Jun 2009
    #606
    as i promised the pics.
    di ko pa nalilinis engine bay. )
    Sep 2010
    #607
    Thats interesting Sir JANVIOS. Kumusta performance?
    I am using the stock air filter with a gadget (combustion enhancer) that is placed doon sa inside nung yellow part ng stainless tube na pinost mo. This gadget is designed to make air intake circulate well in all pistons (?). It results in more power lalo na sa acceleration when overtaking, at smoother ang takbo.
    Nov 2007
    #608
    wow ganda nyan pre!
    pwede bang yung tubo na lang bilhin ko, meron na kase ako filter eh ehehe. anyways ito cguro mod ko come 2011
    Jun 2009
    #609
    Quote Originally Posted by janalla View Post
    performance wise, noticeable agad ang extra hp. though its true na magiging mas maingay pa ang engine natin, doesnt matter since sanay na sa maingay. haha!
    haven't tried that gadget of yours though. masasabi ko sa power na dagdag ng ganitong filter.. hmm lets put it this way. with a full load, 120kph is easy on slex. i can go faster but the road's just short.
    Jun 2009
    #610
    wow ganda nyan pre!
    thanks!
    im not sure kung pwede bilhin yung tubo seperately sa blade. but im suggesting to try and canvas ng ganung tubo sa mga gumagawa ng mufflers. measure the diameter nalang. i forgot eh sorry.
    this 2011 im planning to change the exhaust pipes from manifold to tip. making it bigger and wider would simply give the engine more breathing room. i just figured that with this kind of filter, more air is being inhaled. now it needs more room to exhale.
    goodluck on your project sir! ;)
    Nov 2007
    #611
    thanks!
    thanks! keep us updated also on the exhaust upgrade, parang gusto ko rin yan ahhihih!
    Aug 2009
    #612
    HAPPY NEW YEAR!!! :party: mga fellow tsikoters....
    Nakaka excite at interesting nman po yung mga e-momodified nyo this coming 2011... Samaaa po ako dyan! hehehe....Make our beloved isuzu xwind more powerful & fast..... Thanks! sa mga pix & infos mga sir's....
    Feb 2005
    #613
    [SIZE="5"]OT Muna:[/SIZE]
    [SIZE="7"]HAPPY NEW YEAR Tsikoteers!!![/SIZE]
    May 2008
    #614
    [SIZE="5"]Happy new year!!! :bounceD:[/SIZE]
    Nov 2006
    #615
    mga sirs ilan ba engine support ng crosswind and where it is located?transmission support meron din po ba?panu po malalaman na sira na medyo malakas kasi vibration kapag 750 lang rpm ko e?TIA
    #616
    ask ko lang po sana regarding backup sensor if normal ba to hear an initial long beep when you shift to reverse? I was expecting kase to just hear a short beep telling you that backup sensor has been activated. It's been like this since I acquired the vehicle, kahit walang obstruction, nakakahiya sa mga passengers ko coz talagang masakit sa tenga. the rest of the beeps naman works normally when detecting obstructions.
    Feb 2005
    #617
    Quote Originally Posted by ravelcop View Post
    No worries, that's normal.
    May 2009
    #618
    hello to all tsikoteers!!Happy new year to all!!
    Sir Benz and All Gurus...
    tanong lang kung ano ang maximum diameter ng brake drum ng crosswind (rear)?ano po kaya ang max diameter nito due for replacement?saka nagsqueak na ang brake lining ko sa likod eh eventhough not using the brakes..indicating na manipis na lining..mga ilang months pa kaya pwede itagal nun? and lastly magkano po kaya set nun including the drum sa Jaysons or sa Casa?thanks po...
    May 2009
    #619
    hello po ulit..
    hello sir Benz..
    I hope you could address my problem to your Isuzu friends and contacts...bale yung bench type po kasi na upuan sa front ng crosswind ko (XT 05) ay napunit yung leather niya sa back then upon checking may flat bar that serve as back support na napakatalim or talas ng edges niya kaya napunit yung leather niya (around 24 inches). Bale nakatapat po ito sa tuhod (knee) ng nakaupo sa 2nd row and ang worry ko makahiwa ito sa nakaupo sa 2nd row kasi sobrang talim talaga niya..will post picture po soon...kasi safety related din po ito..
    Dec 2010
    #620
    mga master/s questions lang po.last time may leak po kasi yung power steering.per checking yung power steering hose ang may prob.
    so ni replaced po nila yung hose.ngayon po parang may naririnig akong parang may contact ng metal to metal pag naka center
    position yung manibela, pero dati wala po sya ng may leak pa.
    heto po yung tanong:
    may effect po ba pag ibang ATF ang nalagay/naidagdag, let's say hindi sya DEXRON compliant?
    ok lang po ba i drain yung ATF na ipahigop or mas ok na magdisconnect ng hose?
    ano po ba ang best practice sa power steering, ATF or yung talagang power steering fluid po?(pros and cons)
    ano pa po kaya ang possible remedy?
Isuzu Crosswind Owners Thread [continued]
