Good to hear! It'd probably loosen up further as the kilometers pile up. My personal preference would be either Unioil or Seaoil diesel. Unioil due to it's cleaner Euro 4 rating, and Seaoil by dint of it's STP fuel additives. If both are unavailable, I go for Caltex.
Sent from my GT-I9100 using Tapatalk 2
Noted mga sir. Last question nalang po with regard sa paghahalo ng t2 sa diesel. Necessary ko na po b gawin yun as early as now maski di pa ganun kalakas buga ng usok ng tambutso o gawin q lng yun kapag malakas na usok?
Is it really necessary?I don't use those and my 2003 xuv a/t don't emit black smokes just regular visit to the casa and hose mo yung exhaust pipe to remove carbon build-up
posted via Toyota
Just hose up nga talaga lang yun exhaust pipes to remove the soot, btw, issue sa xwind na mga bago ngaun yung rust resistance ng fuel tank.
Pangit ata subcon ng isuzu daw ngayun sa kanilang fuel tank, so check your fuel tank or filter for rust sediments...
We have 2014 Isuzu Crosswind (current Odo: 6200KM). Regarding sa fuel, pansin ko po medyo rough ung takbo nya nung nagpa fill up ako ng Unioil EuroIV diesel, then tinry ko magpakarga sa Seaoil, mas naging pino ung andar nya tsaka swabe ung takbo.
Guys and recommended nyo accessories for sportivo 2011 thanks
Posted via Tsikot Mobile App
Asslift, tire cover, projector headlights.
sirs, may muffler cleaning scheme ba kayong pwede ma-recommend? repeated water pressure before emission testing lang ang nagagawa ko. any procedures, solvents, liquid solutions na recommended ay malaking tulong.
salamat!
Curious lang kung Ultra-Sulfur Diesel na ibinebenta ay mayroon specification, it should not smoke if the sulfur is <7ppm, The unit i ran produces <1 ppm and based on the engine results never smoked, Viscosity is also important, the higher the the number the heavier the diesel product kung ang Refinery can get away with the off-spec dahil ang bansa walang paki-alam sa smoke issue talagang KIKITA ang Refinery yung mga additives ay advertising lang to make money. Where the diesel origination is also important... If its from China.. well they don't care what they sells walang quality control and also Pinas don't have the strick environmental guidelines kung meron walang nag follow up basta binayaran na sila ok na (corruption)
Tungkol naman sa corrossion issue... ciguro may halong tubig o yung product ay mataas ang POTASIUM content.. and that salt will corrode in the tank.
Being a consumer.. there's nothing we can do, we can not ask for LABORATORY results every fill-up, best to deal is to switch service station and if the car run better then you stick to their product. FYI
hi, yung exad head unit ko ayaw mg on,, kahit nilinis ko na yung copper contacts nya, anu pa kaya pwede ko gwin? na reset ko na din ( ung maliit na button ) iilaw lng tapus wala na uli, kainis alang music TIA :D
Hi All!
may nasilip akong Connector na walang nakakonek sa pagitan ng grill and Condenser.
i can see 3 pins. is this intended para sa fog lamps?
ang linya nun for switch naka-abang na din po ba?
san banda sa dash po makikita ito?
where to buy fog lamps? and switch?
batangas area po sana.
thanks!
hi crosswind guys, paano palitan yung backlight ng (front) a/c switch? also, ano pong size bulbs nya? (t5?)
thanks!![]()
Yap! Ganda. La naman ako prob so far. Katatapos ko lang magpa PMS 1500km. Binabyahe ko kasi Manila to Pangasinan. Nakaka 18km/L FC ko. Nagiimprove habang tumatagal.
Pang harabas talaga yung Sportivo. La ako kaba mapa rough road, uphill or kahit mabigat dala no prob.
Wala rin comment na matagtag sa mga passengers. Roomy din. Hindi naman kami nasisikipan, basta wag lang pasakayin matatangkad at matataba sa 3rd row.
guys, can anyone post a picture of the secondary fuel filter assembly of the crosswind? and anyone knows where can i find 1?
thanks
