Results 3,191 to 3,200 of 3710
- Apr 2009
- 551
December 14th, 2015 09:31 PM #3191
Yung sa XTO ko nagpalit ako 6 yrs ago hanggang ngayon hindi pa ko nagpalit. Seiken clutch master bili ko if i remember
right 1,500. sa secondary clutch last year lang ang brand Asahi 450pesos. magandang brand Seiken Japan made. pero kung
you can go to Walco Banawe replaced it with OEM na. Sure naman na magagamit mo for a very long time.
December 15th, 2015 10:49 PM #3193
1. Yes, it is possible I think it will cost you more or less than 35k
2. There is a lot of choices these days. How many holes does the wheels of the XTO has?
3. Yes you can and you can even install a roof rack or it will look nice if you install a Crossbar rather than the roof rails it looks euro and unique ehhe
- Dec 2015
- 32
December 16th, 2015 08:10 AM #3194Thanks ng marami sir, nilagay parin 4 liters ng coolant sa radiator ko, palagay ko magbawas nalang ako para safe din kasi alam ko dapat 50/50 lang or less coolant over water like 60 / 40, kasi alam ko mas lalakas ang init pag mas marami ang coolant pero palagay ko talagang dapat maglabas ako ng coolant para sure din
thanks ulit sir.. :D
- Dec 2015
- 32
December 16th, 2015 08:22 AM #3195Hello po sa lahat, again I need some opinion,
Hindi ko po talaga masolve ang problem ko sa smoke, ang sasakyan ko po ay crosswind xuvi 2003 model manual transmission, Ang naipagawa ko palang po ay ung mga nozzle cleaning, bale ang ginawa po ay apat cleaning, pasado ung dalawa sa 180 + pressure pero yung dalawa nung una 160 lang nakukuha, pero ginawa nung nagcacalibrate is inadjust ung spring at metal polisher nakuha naman ung 180 pero medyo hirap, palagay nyo po ba ito ang cause ng smoke or baka pati injection pump ko ay may problema na? ayaw ko pa kasi ipagalaw ang injection pump dahil sa takot na baka daw may sira ito dahil ung mismong cleaning at maintenance pala ng injection pump ay instant 4400 php na? reasonable po ba ito na presyo ng calibration? tapos kapag daw may sira na parts sa injection pump ay papalitan depende daw po pero naguumpisa sa 2k to 4k plus daw per parts ang possible na masisira kaya umurong ako at napagisip isip ko na dapat ang budget ko ay hindi bababa sa 10k or more para handa sa maging possible na sira ng injection pump? ang katanungan po ay reasonable po ba ang presyo na binigay sakin ng calibration center dito samin? at mawawala na kaya ang smoke na nakakairita lalo na pag malamig pa ang engine? also, may nabasa po ako sa forum na pwede daw haluan ng 2T ang diesel para less smoke at smooth performance ang ibibigay ng engine? totoo po ba ito? if totoo, what po kaya ang marerecommend nyo na 2T? tama po ba ung nabasa ko na ratio na 200ml 2T/ 40Liter diesel or atleast full tank? Hindi po kaya makakasama ito sa engine and injection pump ko? badly need suggestions and opinions po about dito, I'm having hard time sa usok ng sasakyan, nung may hilander xtrm naman po kami 9 years ago which is binili namin ng brand new hindi naman ganito kausok, I'm just wonderin parang napabayaan ang crosswind sa dating owner, ano po kaya maadvice nyo? bale ganito po pala ang pagusok ng crosswind ko, usually pag umaga fresh start may malakas na usok, tapos may usok parin while reving, pag on idle at pinapawarm up ko sya, either blue or white smoke ang nakikita ko na binubuga nya pero hindi naman makapal tulad nung 1st start, tapos minsan nawawala pag medyo mainit at mainit na pero pagnew start ulit tapos on idle lang and not running, meron nanaman, hindi ko na po alam gagawin ko, pinalitan ko na fuel filter, pinalinis ko rin sedimentor, new change oil, newly cleaned air filter, ang pinakalast na suspect ko talaga is injection pump at gusto ko paevaluate yung nozzles ulit sa ibang calibration center kasi ung una kong pinagpalinisan ng nozzle adjustment lang sa spring ang ginawa at ayaw palitan mga nozzle dahil ata mahal bawat isa, badly need some advice guys, hoping someone could help me with this burden, All I want is for my crosswind to run cleaner with smoke.. by the way sa consumption ok lang naman sya, pero mas matipid parin ung isa namin na xlt jeep dito sabagay nagaircon kasi ako sa crosswind, ewan kung ok lang ba consumption nya.. anyway.. sana may makatulong po..
- Feb 2015
- 7
December 16th, 2015 07:31 PM #3196Makikitanong na din po ako. Alam ninyo kung magkano tie-rod set para sa crosswind?
December 16th, 2015 08:13 PM #3197
- Apr 2009
- 551
December 16th, 2015 09:41 PM #3198
Yung crosswind ko dati ganyan pag start may white na bluish smoke pag start up pag mainit na nawawala, itim na usok na pero hindi naman gaano, naisip ko din yan pero maayos naman hatak at okay naman Fuel consumption. kaya ginawa ko
tyaga lang change oil and change filters. pati air cleaner replace ko every 2 years kahit mukhang malinis pa. sabay 2t pag full tank. sa umpisa 1 bottle very full tank itong past 2 years half bottle na lang. ayun now pag sagad rev lang siya
umuusok at nawawala din. sa cold start hindi ko na nakikita yung white or bluish smoke. yun lang hindi maalis yung amoy ng unburned fuel. kung ako kung maganda pa hatak at Fc try mo muna 2T and regular maintenance lang.
December 16th, 2015 11:45 PM #3199
December 17th, 2015 12:08 AM #3200
Just thought it was too cool not to share:
Nabasa ko lang sa mga comments sa blue app sa tingin mo ganyan kaya nangyari ? "Hindi yan disgrasya...
