Results 2,321 to 2,330 of 3710
- Apr 2013
- 4
April 27th, 2013 03:50 AM #2321
- Apr 2013
- 21
April 27th, 2013 06:29 AM #2322As i have said, ipagawa minsanan yun pang ilalalim, lahat. I'm not saying that you dont have the parts above the chassis checked. pero madali na lang kasi makita diprensiya sa ibabaw, and most often than not we can "DIY" those non-mechanical parts. sa pang ilalim kasi, even if you understand the engine and parts, you would still need precision tools, sometimes electronic tools, and the appropriate workshop.
Sa ganun paraan, masasabi mong kilalang kilala mo na ang isuzu truck mo. kunting langitngit alam mo na may diprensiya at hindi yun "dati nang ganyan nuon nabili ko'. And from there on, keep it maintained regularly. "DIY" if you can, if not, bring it to a good shop.
now before you go on a trip (but this is also ideal to do every morning), check the BLOWBAG, it is an acronym for Brake Lights Oil Water Battery Air Gas.
Good luck
- Apr 2013
- 21
April 27th, 2013 06:37 AM #2323*silvercrest
check this out, BLOWBAG is explained in details here
BLOWBAG your every trip? « The House of WardsLast edited by SportivoX; April 27th, 2013 at 06:40 AM. Reason: additional info
- Apr 2013
- 4
- Oct 2012
- 26
May 4th, 2013 09:20 PM #2325mga sir ano pa ba kailangan gawin sa sportivo ko para mawala yung pagiging mausok nya? medyo delikado na kasi eh.. madaming asbu sa kalsada. suki pa nman mga isuzu dun
maraming salamat po
- Sep 2008
- 295
May 4th, 2013 09:42 PM #2326Try using 2T oil with your diesel. There's a thread here discussing the use of 2T oil as diesel additive. Search mo na lang. I myself am using it in my 2012 sportivo and so far I'm happy with the effect. Less smoke and mas pino ang andar. You can find in the thread the proper diesel-2T ratio but for me, I just put 1 small bottleful every full tank.
May 4th, 2013 09:43 PM #2327
you can try adding some engine oil additive/engine oil treatment...like STP smoke treatment, I once used WHIZ engine oil additive which is quite resolve the smoking and vibration issue of our Pregio (btw, I used two cans of it
though it only prescribed to used only one can for moderate mileage engine) it is noticeable that the thick fog of white smoke is gone during start-up in the morning and everytime I rev it hard it only blew a thin traces of smoke. Thanks to that additive.
- Oct 2012
- 26
May 4th, 2013 11:39 PM #2328
- Sep 2008
- 295
May 5th, 2013 08:38 AM #2330
^ Add ko lang mga sirs... subok ko na 'to!
http://tsikot.com/forums/engine-fuel...il-fuel-79879/
Good Morning!Last edited by joemarski; May 5th, 2013 at 08:41 AM.
well, i have never met a victim admitting they maltreated their trans box...
The Toyota Fortuner has landed (fortuner pics at...
