Page 232 of 371 FirstFirst ... 132182222228229230231232233234235236242282332 ... LastLast
Results 2,311 to 2,320 of 3710
    Apr 2013
    #2311
    Good day Sir/Maam. Newbie to tsikot forum, I've recently included Isuzu Crosswind Sportivo X JS MT(1.140M) to my list along with the Isuzu Dmax LX(993k) & newly added variant 2.2 Ford Ranger XL 4x2 Hi-Rider MT(959k) chosing the one to be purchase this year. Is it ideal/worth to purchase Sportivo X over his counterparts near/little over P1M price category midsize suv and pick ups now? Is there promos worth P75k applicable also to bank financing like BDO/BPI?
    I know Crosswind Sportivo terms of Reliable,durable, fuel efficient, low maintenance & long lasting that why its more appealing mostly OFW's, businessmen & budget wise people here in Davao Region. I prefer a vehicle thats big & hauling some stuff mixed with family use also. Hope you'll give me thought before I chose the right vehicle for me. Thank you & God bless!
    Jan 2008
    #2312
    good day sirs.
    just hoping for some help & input.
    I drive a 2010 crosswind XL, recently, we've been experiencing low power, engine stalling problems.
    There are instances when i remove my foot from the accelerator to shift gears, or to go neutral on a full stop, the engine shudders & stalls.
    I have diffculty restarting the engine. It usually takes around 3 clicks.
    It started last year around November 2012. At that time, odometer reading was 17,500+kms.
    We had it checked & was advised to have the fuel filter replaced.
    I thought it was odd since we just replaced the fuel filter during 10,000km PMS & as per ISUZU recommendations, interval for fuel filter replacement is every 10,000kms.
    We also had the fuel tank/pump/lines checked & was advised that everything is OK.
    We were advised that the fuel flter was dirty & had to be replaced in order for the engine to run smoothly.
    Everything was OK since December 2012 until less than 4 months later, i started experiencing low power & engine stalling problems this April 2013.
    I had it checked out & it the fuel filter is clogged again after 4months/ 1500kms.
    Concerned, we investigated further again & was NOW advised that the clooged fule filter was caused by rust particles forming inside the fuel tank.
    Has anyone experienced this? what can be done? what needs to be done?
    thanks in advance.
    Jul 2012
    #2313
    goodmorning, exactly we aleady experienced the same situation in your car. We brought it to isuzu makati:
    1. they examine the diesel coming from the tank and found out that the diesel was contaminated by rust.
    2. then they pulled down the tank it was the culprit cause of many particles of rust that cause the car don't run or perform well..
    3. they suggest to cut some portion of tank which was affected by rust, and had to replace a metal or whatever just to replace the cut portion of tank they said and will weld it.
    4. In short it was finished within 3 days and pump by pressure the fuel system lines or tubes.
    5. then finally replace new fuel filter. now our car is okay.hope this would help.
    Apr 2013
    #2314
    * Miners,
    Choosing between a pick-up and an AUV is a matter of your need or planned used. Choosing between brands and models is a matter of your wants or preferences, like looks, size or space, power, speed, fuel efficiency, durability, amenities, safery, etc. you cannot have them all in one model, that's why you set your preference where one will compensate for another.
    in your case where you will haul mixed stuffs, it seems that you need a pick up (my personal opinion). Choosing among the brands and models of pick-ups is now a matter of preference.
    usually, one gets the discount (where you mentioned 75k) even with bank financing. In my case the dealer gave me the discount and more. Talk it out with the dealer's agent or the bank manager.
    good luck
    Sep 2009
    #2315
    Quote Originally Posted by holdencaulfield View Post
    hello po! may PCV ba ang mga crosswind natin? gracias!
    yohooooop anyone?
    Apr 2013
    #2316
    Mga Sir, I have an old Toyota corolla car, ok pa Siya , walang problema ang makina at matipid sa gas, kaso lumalaki na pamilya ko, nagbabalak kami ni misis na bumili ng Isuzu crosswind o sportivo. Budget namin Mga 400,000 plus 50,000 para sa repair bago ibiyahe sa probinsya. Mga anung modeling ang kaya bilhin sa budget na 400,000?
    Maraming salamat po.
    #2317
    Quote Originally Posted by SilverCrest View Post
    I'm selling my 2008 XUV. Brandnew namin to nakuha way back July of 2008. wala ka na ipaparepair kahit iuwi mo to ng probinsya. ODO reading is 68,xxx. Casa maintained to eversince kasi this is my wife's company car and were selling it now. two toned color nya, Black. Call me if your interested. 09209094248.
    Apr 2013
    #2318
    I'm sure you can find a good buy with your budget, stick to your plan - xuv or sportivo.
    I just would like to give my unsolicited advice on your 50k repair budget. whether or not the unit you'll buy will look perfectly well, have the under chassis parts (pang-ilalim) like nuts, bushings, ball joints, etc. checked at the casa, all of them. if there's a part that is starting to be broken or already loose, change it. if it comes with a pair, say left and right or up and down, change the other as well.
    i did this to my previous hi-lander slx which was 8 years old when i bought it, i spent 30k including minor body repair, i was worry-free for almost two years.
    enjoying searching for your crosswind.
    Apr 2013
    #2319
    good day. i own a Isuzu Crosswind 2002 XUVi AT and im planning to replace its transmission since i cant run the vehicle more than 60kph.
    eventually we were advised to change its transmission.
    can you recommend a shop where we can acquire and replace the parts, aside from the casa?
    Apr 2013
    #2320
    Quote Originally Posted by lastpogi View Post
    Lastpogi,
    Andito pa po ako sa Ibang Bansa, pwede padala mo pic ng xuv mo sa email add ko. silvercrest910*yahoo.com
    Thanks
Isuzu Crosswind Owners Thread [continued]
