Results 1,431 to 1,440 of 3710
May 18th, 2011 09:44 PM #1431
- Aug 2009
- 349
May 18th, 2011 11:54 PM #1432
- Aug 2009
- 349
May 18th, 2011 11:59 PM #1433[QUOTE=im_mblue;1746149]Hehehe... Sir Red, under the hood kasi may insulation yun for heat
and for acoustic (noise dampener din) isa ito sa mga naisip kong pinagmumulan
ng noise or puwede ring yung hood lock na rin na loose na kaya hindi na lapat
na lapat yung hood pag sinasara...meaning may singaw na both sa init at ingay.
Getzz.. kuna sir but mine yung hood lock nya eh medyo loose na sa kakabagsak ko sa pagsasarado. Instead mas ok parin pala na "press" down munalang ng kamay mo yung hood bago isira para iwas "loose"...
May 19th, 2011 02:15 AM #1434
Getzz.. kuna sir but mine yung hood lock nya eh medyo loose na sa kakabagsak ko sa pagsasarado. Instead mas ok parin pala na "press" down munalang ng kamay mo yung hood bago isira para iwas "loose"...[/QUOTE]
Ingat din sa pag push down baka magkaroon ng dent o mayupi. 2-3 inch bago bitawan pwede naman ata.
May 20th, 2011 04:09 AM #1435
*Benz,
Tatanong ko lang kung may magkakaissue sa offset itong ganitong specs ng rim. Thanks.[IMG]\
May 20th, 2011 06:45 AM #1436
Yes axle oil yung sa rear solid axle, shell SAE 140 would be ok. Gear oil for manual tranny mo naman, shell sae 90 or similar viscosity rating unless specifically may required na iba yung manual. Much better to use synthetic like valvoline to prolong the life of the gears and axle since every 20-30K kms naman palit eh.
Fasten your seatbelt! Or else...Driven To Thrill!
May 20th, 2011 08:42 AM #1437
The specs seemed to be like OEM --- only that the rim width is 8"! OEM is only 6.5" (or 7") A knowledgeable (and trusted) rim/tire shop should be able to decipher if that spec would fit a Crosswind without issues. Oh, correct tire specs (particularly width and flat rate) would prove important too.
Slightly OT: Got pic of the rim in that box to show us? Hehehe!
BANNED BANNED BANNED
- Jul 2008
- 99
May 20th, 2011 09:34 AM #1438Korek, kaya nga napataas ang kilay ko dun sa isang mekaniko dito malapit sa amin na dinedemo nya kung paano magsara ng hood kasi nakita nyang medyo natagalan ako sa pagsara ng hood ko, e pinasingit ko para makita yung paraan nya, e ang style ba naman ay yung iaangat ng mataas at bibitawan...huh, nainis ako kasi ang problema sa latch pa rin e, kapag tabingi na kahit ilang bagsak pa gagawin mo hindi talaga nya kakagatin yung bar, kaya ko isinasara na lang ng dahan-dahan tapos alalay ng dukot sa ilalim ng latch lever para kumagat ng maayos na hindi lumalabas na galit ka sa crosswind mo hahaha
... shy kasi ako e
ayoko ng iskandalo hahaha.
- Mar 2010
- 143
May 20th, 2011 11:46 AM #1439may nag recommend sa akin na i-adjust yg yung injection para lamakas hatak/bumilis Xwind AT ko. parang advanced setting ata yun. Safe ba yan?
Pros and Cons appreciated.
- Jul 2008
- 99
May 20th, 2011 01:05 PM #1440Been trying to educate myself on some concerns on the diesel engine
and I came across your concern in this thread of DIESELDUDE:
http://tsikot.com/forums/showthread....lp-Desk/page28
Here's a quote from this thread:
I would encourage you to take some pointers on that thread...hehehe, pareho tayong matututo from
the experts.
Hyundai Santa Fe GLS 2024
Tsikot Hyundai Registry
