Results 1,581 to 1,590 of 1770
July 18th, 2010 11:46 PM #1581
Did you do some electrical-related modifications on your vehicle? If yes, check on the load requirement of that mod. If not, it could be bad grounding. You can be sure by bringing your vehicle to a reputable electrical shop i.e. Wizzard. have them check your wiring vis-a-vis alternator charging.
July 19th, 2010 12:33 AM #1582
san yung location ng Wizzard sir?
may sakit kasi yung xwind, minsan di nag chacharge ng battery.
one time galing kami nag grocery. i turned it off, then i opened our gate, pag balik ko sa car, ayaw na mag start. minsan pag mornings ganun din. turo sakin nung kakilala kong driver kargahan ko daw muna before turning the engine off. seemed to work. but i dont want to settle for this. hindi naman kasi sya ganun dati.
small audio upgrade has been done
replaced stock speakers sa harap(70wRMS) chaka sub(300wRMS) sa likod running on a v12 amp. very light setup lang. pero this was intalled AFTER the car developed this problem. baka na enhance din ng audio upgrade yung problem.
also one night nag ddrive ako in front of an owner type jeep, napansin ko yung headlight ko nag didim then lalakas pag apak sa gas pedal(yung parang sa mga tricycle). asked my friends on what they think is the problem, sabi alternator daw malamang.
July 19th, 2010 05:55 AM #1583
- May 2009
- 119
July 19th, 2010 12:17 PM #1584hi guys...eto experience ko sa crosswind ko...fill-up to the brim then reset trip meter sa odo..it already ran 764kms pero wala pang indicator light ang gauge ko kaya nag-fill up ako bale 49 liters ang nakarga so may 6 liters left pa sa tank kaso lang di siya umilaw di ba dapat iilaw na siya kasi 6 liters na lang or dapat mas mababa pa?pero ayus na ayus average ko 15++ per liter mixed hiway and city driving...hehehe tipid talaga ng crosswind natin...
July 19th, 2010 12:28 PM #1585
- May 2009
- 119
July 19th, 2010 12:34 PM #1586sir bob thanks...di ba dati sa post nyo nasa more or less 8liters remaining sa tank eh dapat maglight-up na yung indicator...6liters na lang remaining eh wala pa din..what do you think di kaya busted yung bulb or mag try ako 800kms on one full tank...hehehe kaya naman siguro yun ng crosswind...thanks...
- Feb 2010
- 194
July 19th, 2010 01:50 PM #1587Please help me on this. . .
How can i remove the bolts attaching the filler and the fender. . .i wanted my headlight to be cleaned kasi nagmoist, kaso hindi ko matangal. . .sabi ng mechaniko, kailangan tangalin ang bumper para matangal yong bolt ng filler. . . btw, tong filler yong nasa baba ng headlight na nakaatached sa fender. . .
thanks in advance. . .
July 19th, 2010 03:19 PM #1588
- Mar 2010
- 143
July 19th, 2010 04:03 PM #1589[Mods, pakilipat na lang in case meron mas appropriate na thread.]
I do recall a discussion about delays from LTO in issuing/releasing plates for new Isuzu cars. As far as I am concerned, this claim from the dealers is plain excuse. I have to check LTO pasay myself to learn otherwise (300 plates ang available at that time). Obviously, walang follow-ups from the Dealer. Mine is a regular plate (with specified ending for color-coding). Ayun, nakuha ko in a week after kung magalit at makulit ang dealer. Yun lang, kelangang personally lakarin sa LTO office. But If you're like me na ayaw ma-hassle while driving, esp in Makati, it's worth the time.
Sabi nga ng LTO, ginawa pa silang sangkalan ng dealer inefficiencies.
- Feb 2010
- 194
July 19th, 2010 05:14 PM #1590Thanks Sir Benz. . .for 2005 up, please refer to No. 5. . . that can easily be remove becase of the gap between the bumper and the molding. . . however, the molding also bolted with the fender (not shown in the illustration). . . if the molding (filler) will not be removed, the bolts under the headlight (illustration no. 7) will also be hard to remove. . .
pero i think i got an idea, sa ilalim baka pweding dukutin and screws under the headlight. . . then there's no need to remove the molding (filler). . .
Thanks.
Yung extra AUX Fan is useful sa mga naka montero. Mag improve daw yung AC system since may extra...
