Results 121 to 130 of 1770
January 9th, 2007 08:05 PM #121
January 9th, 2007 09:02 PM #122
Isuzu provides diesel engines to our public utility passenger jeepneys. Crosswinds and Sportivos are the civilized version of it. So go figure.
Engine noise is unacceptable especially on long driving that you needed to play a Motorhead concert on its entertainment systems to compensate. You have to drive the likes of Sorento, Santa-fe or Fortuner which also have diesel engine to be able to check the difference.
Interior is cheaply made, that plastic door handle was removed when i closed the door of their display unit, and you bet quality would not pass by Topper ware standards.
January 9th, 2007 09:55 PM #123
January 9th, 2007 11:00 PM #124
Almost anything on the market exceeds CD grade nowadays. Even the run-of-the-mill Shell Rimula X black they sell at Shell. SAE xxW-xx refers to viscosity. It is a separate rating apart from the grade. You don't have to mind the W part much as there is no winter in the Philippines. 30 or 40 is the usually accepted viscosity for local conditons.
January 10th, 2007 07:19 AM #125
I use Rimula X on my Dmax. IMO, as long as you change your oil regularly, its okay not to invest on those high end (and take note expensive) oils. If they offer them discounted however, its always good to let your engine taste some class A oil. hehehe.
January 10th, 2007 10:36 AM #127
kelan ba maglalabas ng ALL NEW crosswind?
grabe na ang facelift sa current crosswind ah...pati pagdagdag ng mga electronic gadgets at rear cam e pinagmamalaki na sa ads...e accessories lang naman mga yan
January 10th, 2007 11:00 AM #129
maybe 2008, for me even with the current flatform but with a 4JH-1
engine option will do.
Somewhat expected from a rushed car from a first time carmaker
Xiaomi E-Car
