Results 11 to 20 of 34
- Sep 2005
- 141
- 10,620
- Sep 2005
- 141
October 28th, 2005 02:02 PM #13Mga bro sino kaya may service manual/owners manual sainyo ng bighorn?Tnxz!
November 11th, 2005 03:58 PM #14
saan kaya or sino magaling magpalit ng timing belt ng 4jg2 engine? pwede ba pa share naman ng service manual/owners manual ng bighorn nyo? thanks.
January 25th, 2006 07:39 PM #15
- Aug 2004
- 108
April 21st, 2006 12:11 PM #16Originally Posted by mcbry
I had the same problem with my bighorn before. if your bighorn has the electronic climate control panel the problem could be the thermostat located on that panel. apparently that climate control panel uses cabin temperature to switch-on and off the compressor. during conversion the wires could not have been returned properly or the electronics have been damaged.
What I did was deactivate the climate control and just installed a manual knob type thermostat. Problem solved pero yun lang nga aesthetic na lang yung climate control panel.
Another problem could be baliktad ang pagkabit ng expansion valve dahil hindi pinalitan ang evaporator nun kinonvert. dapat na sa left yata ang expansion valve and not the right side (pag left hand drive ang kotse kasi yung expansion valve na sa right side). I had to change my evaporator twice before I figured this out.
Ngayon malamig na sya pero problem ko is hindi maganda ang pagka sara ng firewall during the conversion na pag na sa highway ako my pumasok na hangin sa labas kaya hirap magpalamig ang aircon.
May 4th, 2006 12:09 PM #17
- Aug 2004
- 108
May 4th, 2006 06:48 PM #18Originally Posted by attic_dude
May 5th, 2006 12:32 PM #19
- Dec 2002
- 2,335
May 9th, 2006 11:57 PM #20joseph a22bo can fix a.c and electrical problems sa BigHorn. He even made ducts going to the middle vents para gumana yun. A little bit on the expensive side but pulido trabaho. 10K dati binayad ko for pull down ng dash/complete ayos ng wiring/ complete ayos ng AC.
I agree. travelling by train is always the fastest way to travel. kami din dati sa Bangkok, we...
Makati Subway. Completion date: 2025
