can't relate to this discussion as my XTO is a manual onebut i think practice practice lang because getting used to your car is the most important. knowing it's capacity on certain speed can make you feel confident and safe in overtaking.
i had my XUV since 2003 AT rin... para sa mabilisang overtake
PUMP the PEDAL unti you reach atleast 4.5K RPM then try to stay there!
at higit sa lahat,
[SIZE=6]P R A Y H A R D[/SIZE]
[SIZE=3][/SIZE]
[SIZE=3]angel of God my guardian dear....[/SIZE]
Have a boost controller installed, and alcohol injection.
According to DevilDoc, they were able to get a turbo Crosswind's 0-100 km/h times down to 16 seconds (that's nearly twice as fast as stock) with injection.
I didn't see such a big change... but it's possible my XTO has a boost leak, a slipping AT or a worn turbo (130,000-150,000 kms or so...)... still tinkering with it. But I did gain some horsepower with the mod.
Just bummed because I got only 5 hp or so, and other guys with old-school 2.5 turbos are getting 10-20...![]()
Kung papalitan lang din ung transmission i think ang ipapalit ko na is ung manual transmission. I was told pwede daw yon. It its cheaper pa din daw. and I personally thing that is DO-able
But then again di na sya bagay sa forum/topic na to. hehe
If that's possible, do anyone has and idea kung magkano kaya ang Manual transmission assembly for crosswind?
Sa likod. Pero I'm thinking it might be easier to reinstall it in the front passenger footwell, para madaling abutin.
I really think we need boost control... or something... my XTO just doesn't have enough boost to utilize the benefits of alcohol injection. I'd love to tinker with it and see how much more power I can get out of it, but I'm too busy, at the moment with other things.
It was not really 16 second but a little slower like 16.8
Had to manually activate since the switch was a 6psi switch.
From the guy we tested the kit with and won it as well
You can activate it at 2psi on the crosswind and get a noticeable difference in performance.Nice meeting you all guys!
Again thank you dvldoc for the prices, especially I won the kit, what else I can ask more... can't wait to get this installed in my ride. Felt the rush when it was tested on my Crosswind XUVi today (3/22/2008). The Crosswind XUVI A/T with 4JA1-L engine performance is not one of those fast ride known to tsikoteers, but with the Water/Alcohol Injection tested today (I believe used with 35/65 mix), jeeez can't believed it just pulls harder, and harder and faster.
The improvement is very much noticeable at the top end... with the system turned off the acceleration at 60kph going above is slow, but with the system turned on, the performance from 60kph and beyond is a lot quicker. The gain in speed is gradual, but definitely its noticeable. Imagine that 5 sec drop at 0-40mph as logged by dvldoc's accelerometer.
buti nalang M/t ung akin.. 0-100kph kaya within 12secs. or less.. 3-4k rpm.. 100kph on 3rd gear..
Not with mine. I have a sneaking suspicion that either my turbo is shot or it's leaking boost, since the gains on my car are almost in line with gains on a naturally aspirated vehicle! Will test it one of these days when I have time.
Not with a Crosswind.
In the back of the vehicle. or get a custom tank that slips under the rear seats. or under the vehicle with a refill spout. Lots of options.
* niky
Your turbo might have a issue because almost everyone will notice a nice bump in power and drop seconds off there 0-100kph times. When I put it on my 1999 starex in May it was like a different vehicle.
for me kailangan magpatay ng aircon tapos sa alam ko me binabanggit sila na teknik na pagtapak sa pedal para magdownshift hindi ko lang alam kung pwede ito sa crosswind
ahh im glad manual lahat ng auto namin haha
gawa ko pag nag oovertake ako eh floor ko yung pedal tas konting angat ulit tas floor ko ulit sya na parang binobomba ko hangang maka overtake medyo mabilis bilis ang response nya yun eh from 80-100kms pero pag nasa 100kms and more kana hehehe parang pagong kung umakyat yung speedometer hehehe hinahayaan ko lang naka off yung OD ginagamit ko lang OD pag umaakyat kami ng baguio
Ad lang po ako about the a/t xuv, mine 02 xuv. since na ginagamit ko ito kahit mag overtake ako hindi kuna ina activate yung OD nya! Timing lng talaga kapag nag oovertake at medyo risky ngalang. By the the way wag nyunang sabayan yung mga PUJ especially kapag rush hour, talo pa kayo sa pambayad sa accident. THanks!
sa mga m/t naman
eto sa akin pagoovertake
3rd gear muna until it hits 2.5-3k shift sa 4th gear habang umoovertake.. ayun lusot
90kph pasok
