Results 11 to 12 of 12
- May 2009
- 119
March 31st, 2010 09:14 AM #11check and verify kung oil kasi kahit coolant eh didikitan din ng dirt at eventually magiging oil look alike siya the reason na namention ko ito eh baka may leak na ang seal ng water pump mo...ganyan din nangyari sa akin..nag DIY ako buying an replacement water pump pero Japan (GMB brand) ako na nagkabit madali lang as other guys said in this forum you just need to modify yun bolting...pero ipacheck mo muna sa shop or silipin mo yung ilalim ng water pump may butas yun kapag may nakita ka na coolant dripping...water pump replacement na iyo for sure...
April 27th, 2010 08:50 AM #12
sir your right.. coolant pala yon hindi oil.. sorry noob lang me with diagnostics.. nywyz its fixed na. i have a faulty rad and water pump and i got it fixed months ago. the coolant dried up and looked like oil leak
high idle RPM at engine start
