Page 77 of 83 FirstFirst ... 2767737475767778798081 ... LastLast
Results 761 to 770 of 822
    #761
    Hi Sirs,
    Need your help. My wife got the key of our bighorn stuck sa may ignition. Hindi namin matanggal. Sabi sa mga forums meron daw button na nipepress for this kaso hindi namin makita. Meron ba talaga? If so, san kaya ito located?
    Jun 2004
    #762
    installed ome coils. with the monroe magnun shox. i'm very very happy with the ride:-)
    Jun 2004
    #763
    bro. if your rig is automatic. try shifting the gear lever to L the back to P. then try removing the key
    #764
    Hi sir Minkoy,
    Thanks for the input. I tried what you suggested but still, I am unable to pull the key out. It seems what's happening is hindi ko ma fully twist ung key into lock position, parang until half lang siya. Natatakot naman ako pwersahin baka lalong masira.
    Any more recommendations? TIA
    Apr 2011
    #765
    trooper owners, tanong lang po sa regarding automatic trany, I just replace the AFT in the trany about 3 liter ang na drain....
    anu po dapat ang level ng atf nasa HOT or in between ng HOT AND COLD? nabasa ko kasi sa ibang thread na wag sobra at d naman kukulangin... need your input pls...
    #766
    Quote Originally Posted by asher25 View Post
    Since bagong palit yan, cold reading ka talaga. Tapos once you drive it for about 5 mins, try mo tignan na sa hot level. Mas importatnte yun eh. Again drive around for 5 mins ha para operating temp siya. Use A/C para mabilis uminit makina.
    Apr 2011
    #767
    sir, after 30 min driving, i check the AFT the level, the aft was between COLD and HOT hindi pa na ka off ang engine po...kulang ba o tama?
    #768
    Mga sir, yung trooper ng friend ko, local 2003 model, bigla nag-on yung ABS light sa dashboard. Ano kaya problem? Thanks!
    #769
    Dapat dun sa Hot part, may 2 pa yang indicator, dapat in between noon hindi dyan sa Hot or Cold name marking ha.
    Read this: How to Check Automatic Transmission Fluid | eHow.com
    May 2009
    #770
    ok trooper pips, you may find gold for your trups here: www.jeepolog.com.....me found one
Big Horn/Trooper owners
