Page 73 of 83 FirstFirst ... 2363697071727374757677 ... LastLast
Results 721 to 730 of 822
    Jul 2003
    #721
    Quote Originally Posted by mintoy View Post
    Visited the trooper this morning. I saw the mechanic installing the valve body back to the tranny. Bong the owner said that they double checked with the service manual that everything in the valve body was placed correctly. I didn't hear from they this afternoon. so i guess there is still a problem:-(
    I hope they can fix it. Did you do a second opinion before you decided to overhaul your tranny? I have also a problem in my transmission before, there is no 4th gear (OD) and what I did I go to BALTAC shop Auto trans surplus located near in banawe. They diagnosed my transmission and they found out that there is no problem in mechanical but in electronics of my tranny. They checked the computer box by replacing it with their spare but still same result no OD. Electrician make a bypass wire from speedometer to computer box then the result is okay the shifting is smooth and now can reached in 4th gear. I think the guy knows already the problem of my tranny it just make it long procedure to checked so that he can ask a good price. It cost me only 4.5K to solved my problem
    Jun 2004
    #722
    Quote Originally Posted by nap123 View Post
    as of now, they said that they checked all the electrical connections. even replaced the comp box and TPS. still the same. as of this pm, bong told me that after some research. it seems that our trooper is using the wrong computer box. he ordered one. but it will still come next week. so i pulled out the trooper so we could use it for the weekend and i'll bring it back to the shop when the correct compubox arrives. hope it works this time. thanks for the info. i will consider bringing it to baltak if there is no change.
    Jul 2003
    #723
    bong told me that after some research. it seems that our trooper is using the wrong computer box. he ordered one. I'm puzzled to this, how come the one installed to your tranny is a wrong computer box????
    Yes, its better you bring it there. Considering they changed the TPS the comp box how much the cost?, you better contact weng 4711053/7312965/7119736 they have a spare computer box that they can test. The price of computer box is ranging to 12K-17K depending of the demand. That time they will give it to me for 8K but im lucky it was not faulty. They have a good electrical guy there to check the electronics of your tranny. They are honest to tell me that there are no problem in my tranny mechanically otherwise they will suggest to overhaul of replace a surplus tranny that will cost me 30K plus.
    Jun 2004
    #724
    i bought the rig from someone who bought it from a someone. so maybe somewhere down the road. the tranny was opened and the compubox was replaced. the guy i bought it from said that he did not do anything with the tranny, so i guess it happend with the first pinoy owner.
    anyway, the compu box should be arriving anytime this week. if it doesn't work or normalize the tranny. i will try baltak. thanks bro.
    Jun 2004
    #725
    BTW, does anyone know the correct part no. of the computerbox for a 4jg2 auto tranny. thanks.
    Jun 2004
    #726
    visited our trooper this pm. cuz the compu box arrived yesterday. according to bong. the tranny now shifts properly. but during his test drive. the tranny would not down shift when he floors the gas pedal. he suspects there is a problem with the stepdown part of the valve body. he got a surplus valve body from banawe and will install if on monday. hopefully, it will be ready by then cuz we plan to use the trooper for our long drive to bicol this holy week. keeping my fingers crossed:-)
    Apr 2008
    #727
    Hi guys! I have a relative in Baguio. He's looking for a durable and efficient vehicle with which he can bring more people and also do farm work. Now he's looking at the Bighorn and he's on a budget of more or less 300k. Is he looking at the right direction? Are Bighorns, unlike Subic Pajeros, typically worry-free? I don't usually here of problematic Bighorns like I do with Pajeros. What are there to look out for?
    Feb 2005
    #728
    Quote Originally Posted by GTi View Post
    Get a locally-assembled or CBU (but orig LHD) vehicle. That should make you 50% worry-free. The other 50% would be the maintenance of the vehicle (with current owner)
    Apr 2008
    #729
    Quote Originally Posted by Benzmizer View Post
    That's the hard thing. I can't seem to find a local car that will fit his requirements and his budget at the same time. Are Bighorns that bad? It seems to me that Bighorns are less problematic than converted Pajeros. And since its been a long time since these Bighorns are imported, and the mere fact that they are still running, it should be that the owners have already repaired all the headaches that might have been plaguing them, right?
    Feb 2005
    #730
    Maybe so. Ok, best compromised suggestion I could give is look for a well-converted (and maintained) Bighorn. Frankly, my friend owns a box-type Trooper (with 2.8L diesel engine) and in perfect shape!
    Mahirap kasi makipagsapalaran sa isang converted na di mo alam background ng source and converted vehicle. If you can be guaranteed of this, then you're good.
Big Horn/Trooper owners
