Results 761 to 770 of 822
- Sep 2007
- 56
June 18th, 2011 09:04 PM #761Hi Sirs,
Need your help. My wife got the key of our bighorn stuck sa may ignition. Hindi namin matanggal. Sabi sa mga forums meron daw button na nipepress for this kaso hindi namin makita. Meron ba talaga? If so, san kaya ito located?
- Jun 2004
- 290
June 20th, 2011 12:10 AM #762installed ome coils. with the monroe magnun shox. i'm very very happy with the ride:-)
- Jun 2004
- 290
June 20th, 2011 12:12 AM #763bro. if your rig is automatic. try shifting the gear lever to L the back to P. then try removing the key
- Sep 2007
- 56
June 21st, 2011 11:04 AM #764Hi sir Minkoy,
Thanks for the input. I tried what you suggested but still, I am unable to pull the key out. It seems what's happening is hindi ko ma fully twist ung key into lock position, parang until half lang siya. Natatakot naman ako pwersahin baka lalong masira.
Any more recommendations? TIA
- Apr 2011
- 78
June 23rd, 2011 08:39 AM #765trooper owners, tanong lang po sa regarding automatic trany, I just replace the AFT in the trany about 3 liter ang na drain....
anu po dapat ang level ng atf nasa HOT orin between ng HOT AND COLD? nabasa ko kasi sa ibang thread na wag sobra at d naman kukulangin... need your input pls...
- Apr 2011
- 78
June 24th, 2011 09:39 PM #767
June 25th, 2011 06:23 PM #768
Mga sir, yung trooper ng friend ko, local 2003 model, bigla nag-on yung ABS light sa dashboard. Ano kaya problem? Thanks!
June 25th, 2011 06:45 PM #769
Dapat dun sa Hot part, may 2 pa yang indicator, dapat in between noon hindi dyan sa Hot or Cold name marking ha.
Read this: How to Check Automatic Transmission Fluid | eHow.comFasten your seatbelt! Or else...Driven To Thrill!
June 25th, 2011 11:45 PM #770
ok trooper pips, you may find gold for your trups here: www.jeepolog.com.....me found one
A relative of mine in Canada had his Scion FR-S PPF'd and then had it ceramic coated. He says it's...
Ceramic Coating vs PPF (Paint Protection Film)
