Page 707 of 1213 FirstFirst ... 607657697703704705706707708709710711717757807 ... LastLast
Results 7,061 to 7,070 of 12125
    Jul 2013
    #7061
    Quote Originally Posted by Devin miles View Post
    Hi guys. Any one looking for a dependable utility box way better than oem and much cheaper you can text/call sir. Emil ito po number niya. 09178176355. Siya po supplier namin sa MUX GROUP. Please see below sample pictures
    This is sturdy, nice fitment walang alog at hindi maingay. I can vouch for his item. Legit seller madaling kausap at free delivery pa!
    Sir, free delivery po ba pag papuntang vigan, ilocos sur?
    Nov 2015
    #7062
    Quote Originally Posted by bluberto View Post
    Ang OEM lang sir na distributor of TPMS other than Isuzu dealers is Winterpine Marketing. pag sa kanila ka pakabit hindi daw mavoid un warranty and your HU is updated.
    Bumili din ko steelmate TP-05 fr Aliexpress around 7.2k, antagal nasakin pero di ko pa mapakabit kasi other than void warranty, hirap din ko makahanap ng electrician para maginstall.
    Masmaganda pa ata un cig plug/iphone app compatible but not sure about reliability..
    purchase my tpms thru safecar ph
    i have installed a tp05 on our unit and it works fine, wala kasi carguy sa bahay tas si nanay ko lang gumagamit, at least me pang reference din sia kung sakali nababawasan na pressure ung gulong.
    Feb 2016
    #7063
    Quote Originally Posted by ikloyputograpi View Post
    Yan din concern ko, si misis kc madalas din gmitin and mllayo din pinupuntahan. Sir kayo b ung na feature dun sa safe car ph? Na nnonotify k tlga n under inflate n mga tires mo?
    Nov 2015
    #7064
    Quote Originally Posted by leodev View Post
    yep those are my vid/pics which i submitted to them, i set mine 27psi (there are 2 units bar & psi), before i drove out of the mod shop, we try to release the nitros also and it will notify if it goes below that point with beeping sound and will marked as red also. But if you are in the manila region, better opt for winterpines tpms so that your warranty will not be voided.
    Dec 2015
    #7065
    Ang ganda ng mags mo Sir, ano specs nyan, saan mo nakuha at magkano inabot?
    Nov 2015
    #7066
    Quote Originally Posted by Muvanza View Post
    for my setup it is called d551 trophy black with anthracite ring, 20 x 9, +20 offset,
    had a query on fuel offroad fb page and advised me to order it thru local distributor in davao which is tiresmart, probably they have the same supplier with BCC wheels in Banawe, kindly check thru their website for other galleries/details.
    Dec 2015
    #7067
    Noted Sir, thank you
    Mar 2016
    #7068
    Sir kanino ka po nagpa install? I have the unit lang hindi pa bukas, naghahanap lang shop that can install
    Nov 2015
    #7069
    if you reside within region xi, Tiresmart Davao can do it
    Feb 2016
    #7070
    Mga paps air spencer
    ***yboy vs marine squash
    Di ba masyado matapang ang ***yboy?
    Thanks mga paps
All New Isuzu MU-X // Alterra Next Generation
