Normal po b na may engine break ung 3.0 blue power AT?around 100 kph po pag nag release sa accelerator ung rpm biglang tumataas considering po na ung road is flat and not downhill.
rpm *100? before and after?
sure na flat? thats engine braking nga. interesting... set to manual mode?
Good day mga chief. Yung ABS and ESC light sa display umilaw after 2days of the 5k pms. Ayaw na mamatay yung ilaw. This happened while on a long trip back and forth sa bataan. Binalik namin sa service, unfortunately, sira daw pang diagnose ni casa. we will try sa other dealer. May naka experience na ba sa inyo nito mga chief? This casa told us na around 10 cases na daw sila nun. casa ba may problem or sa ibang dealers may cases din?they checked the brakes physically, and told us na functioning naman. :no
bad batch siguro ng battery?
normal in my opinion.. if you want to do 6th gear.. go to manual mode..
yung engine break po b nakaka affect din sya sa fuel consumption?like lalakas if laging nag eengine break?
naka off ang fuel injectors during engine braking...
Hindi kaya confused pa yung engine whether to retain sa kung anong gear ka or to put it 1 gear down kaya bigla nagengine break?
Sent from my LG-H860 using Tsikot Forums mobile app
its a heavy vehicle... mga bus ganyan din siguro.
what was your vehicle before? manual?
Lagi ba ngyayari everytime 100 ang takbo mo sir? How was your acceleration going to 100kph? Di ba biglaan or biglang arangkada going to 100? Maybe nagaadjust yung engine thinking na you're trying to accelerate fast then bigla ka bumitaw sa pedal so kaya sya nagdownshift for you not to lose power?
Here's a video of the turbo whistle on my MUX. It's not too loud, but definitely audible, especially with the windows down. Normal ba para sa inyo? Mukhang ok naman ang power and acceleration. May boost gauge ako on the screen via OBD2 scanner and screen mirroring. Max boost is around 17-18psi.
Apologies for the shaky video. I just used a chest strap.
3.0 4x2 non-bluepower
MUX on Vimeo
major complaint for the 1.9 blue power is the turbo... 😅
