Always shell gamit ko but one time nag karga ako ng seaoil bakit napansin ko mas mabilis yun acceleration nya less delay from full stop.
Sent from my SM-J700H using Tsikot Forums mobile app
San kaya may oem na upper spoiler mahal kc sa dealer 12k
Sa mga nag palit ng wiper what brand and how much yung wiper? My ride is LSA-MT acquired June 2016 with 19.6k sa odo. Tnx much.
Sent from my ASUS_T00J using Tsikot Forums mobile app
I use Würth wipers kasi walang stock ng RainX. Ang di ko lang alam palitan yung sa rear. 😂
Also, kahapon may marning na low voltage na daw electronic key, good thing may spare sa bahay, same battery as our electronic luggage scale.
Sent from my E6683 using Tsikot Forums mobile app
Our unit will be turning 3 years old next month. Madali lang naman din magpalit ng battery basta may flat head screw driver. ☺
Tnx much sir lancer and ikloy!
Hi mga sir, normal lg ba marinig yung clamping of gears when shifting sequence of reverse and drive? Ls-a 3.0 unit ko, wala nman problema sa pagtakbo...13000 na odo ng unit, first car ko kasi to pero bihira ko lg ma drive dhil sa abroad work ko kaya no idea ako kung normal lg ba to sa automatic tranny, sabi ni misis since daw pagkuha ganyan na at normal lg daw sabi ng casa, please advise mga sirs...ty
Sent from my ASUS_Z011D using Tsikot Forums mobile app
hindi patag siguro ang parking... some AT have this issue. even the new fort has this. and the fort guys have a sequence how to avoid it.
Kahit patag po parking at talagang we make sure na nag totally stop ang car bago mag change gear...anu po sequence they use to avoid? Plan ko rin dalhin sa casa d next ff days pag d na busy...thanks po
Hindi na ako maka-mirror ng screen sa HU using my iPhone after updating to iOS10. I was able to before the update (LS-A/AT 2016)
Meron po ba kayong similar experience? We're you able to solve it? I hope you can share how.
TIA
may 15° slope sa kalye sa harap ng garahe namin. eto po ginagawa kung mag-park sa kalye:
1. full stop,
2. with foot on brake, shift to N,
3. pull hand brake until engaged,
4. slowly release foot brake,
5. if mux rolls forth or back, full step on foot brake,
6. pull hand brake one or two notches, as possible,
7. slowly release foot brake,
8. repeat steps 5 to 7 as necessary until mux stays put after step 7,
9. shift to P.
pa-correct na lang po kung kulang o sobra. hope this helps...![]()
step on brake until full stop.
N.
pull handbrake.
release foot brake.
if still moves, pull additional 1 or 2 clicks on handbrake, until stop moving.
put to P. you know you have to put to P, if you want to pull out your key.
you can vary the steps. the end is the same.
i have a couple of dos por doses in the trunk, justin case... (wheel wedges!)
baka ibang gear oil gamit. ginamit nila gear oil for the trucks..
