Had more fun on the first drive home using the mux compared to when i got my lancer three years ago.
At ang luwag and comfy sa loob lalo na nung naibaba sa 35psi yung tire pressure. Will try 33 to 30 psi to figure out saan pinaka ok sa kin.
Value adding din sa buying experience yung pinapanood nila orientation videos took time, na late tuloy sa appointment sa tint shop.
Satisfied din sa free hellasupertone horn (replaced the free tint for this)from the delear.
Downside is parang 1 year lang ang lto registration na kasama. 7k ang nasa cr.
How much ba dapat kung 3 years?
Thanks
Guys I notice some cracks on the part where the intercooler pipe/hose is connected. Is this normal? My ride LSA-MT acquired June 2016 with 16.2k kms. Unfortunately I cant attach the pictures. A message pops out that says "This page is not working". Hu hu hu!
Sir kng madadala nila sa casa for check mas ok kung under warranty pa sasakyan nila.
Sent from my SM-G930F using Tsikot Forums mobile app
Good morning.
Any one tried to DIY a tonneau cover? or may less expensive alternative ba kaysa kumuha sa casa accesories? 16k+ pesos ba naman.
Saw this on pinterest.
Make your own trunk cover | Cars, Pink and Diy car
Normal ba na may warning beep when the speed reaches 100km/h, ang nabasa ko kasi sa manual yung beep naka set if lampas 120km/h.
Thanks,
Interested din ako dyan sa tonneau cover. Tagal ko na naghahanap. Haven't think of DIY.
Sa beep sounds naman depende yan sa speed limit ng road. Example sa NLEX mag beep na sya about 100 kph. Pag umabot ka na ng 120 kph double beep na. Sa commonwealth ave naman nasa 60 kph pa lang mag beep na. Naka preset na yan sa iNav in relation sa location mo with GPS.
Thanks sir!
Sa navi pala yun.
Ask ko tita ko if kaya niya mag tahi ng tonneau cover. based sa pic plastic curtain rods at fabric lang kailangan.
I know hindi siya as accurate ng full tank method of calculating the FC. Sa display ko lang nakita yung average FC.
Natuwa lang at first time ko naka pag paabot ng 18km/L minimal stops hangang end ng coastal road. Nakakainip lang at cruising lagi sa 65 - 74 km/h.
May nakaranas na ba sa inyo na kapag nagpapatugtog (tuner or USB) nawawala yung audio (mga 3-4 seconds) tapos tutunog ulit? Madalas mangyari sa akin tuwing mag-a-accelerate. Mas madalas mangyari noong naka-cruise control ako sa SLEX. Kakakuha lang namin ng MU-X noong April.
The GPS Warnings interrupting whatever is playing; you probably couldn't hear it because the GPS volume is set very low (hence, the silent interruption). You can increase the GPS volume if you'd like to hear what the GPS is saying. On SLEX, you're constantly reminded of "Speed Cameras" (as an axample)
Hope that helps. Cheers!
Speed Camera ahead sinsabi nung GPS and andami pa namang speed camera sa SLEX so every 250m nagsasalita saakin
Sent from my SM-A700FD using Tsikot Forums mobile app
My SA told me before na meron na daw installed cabin air filter ung unit ko. But since it has been a topic here, I went investigating on my own by removing the compartment and the cover. And I found out na wala pala talagang cabin filters mga units natin upon release. So we really need to buy it separately.
However, I have some questions before buying those:
1. Which is better in terms of efficiency in filtering the air, the ordinary cabin air filter or the activated carbon one?
2. How often do you replace them? What are the indicators that you need to replace them since its not really easily accessible in inspecting them.
3. Can the cabin air filter be cleaned instead of replacing them?
TIA sa mga makakasagot.
