Page 468 of 607 FirstFirst ... 368418458464465466467468469470471472478518568 ... LastLast
Results 9,341 to 9,360 of 12125
    Dec 2008
    #9341
    Sir that is a very sweeping generalization kapag sinabi nyo po na mas prone masira electronics. Syempre it depens on the use duty cycle at alaga mo. Remember ang use nya mainly is just to start and turn off the car. I'll bet your radio will see far more use than that. My cousin has an early mu-x kaya wala pa start button but just as per my own experience. My 2005 car had a start stop button never did it fail me until I sold it in 2012 and 82t kms later. Napalitan ko window regulator water punp alternator bearing but not the switch.
    Totally agree ako sayo sir depende pano mo gamitin mas mauuna pa masira HU mo kaysa sa push start button depende na lang siguro kung pumindot ka ay bara bara...
    Sent from my CHM-U01 using Tapatalk
    Oct 2016
    #9342
    Hello...normal lg po ba yung ramdam mu na parang may konting thud sound sa transmission pag nag stop and go ka in slow traffic, parang hindi ko naman ramdan pag galing sa mabilis na takbo going to stop, then accelerate iniisip ko kung sa torque converter lang to na normal to sa automatic tranny...unit ko po is ls-a at 3.0...newbie driver and first car ko...
    Sent from my ASUS_Z011D using Tsikot Forums mobile app
    Quote Originally Posted by Aceboy View Post
    baka kailangan reset ang tcm learn?
    #9344
    May katanungan lang po ako about sa battery, Nag palit kasi ako ng new battery bale 2sm yung stock, ang kinabet ay 3SM.. Ang problem ko lang.. Bakit kaya nag Warning Sign yung ESC simula nong pinaltan.. Kanina ko lang pinakabit yung bagong battery... Motolite Excel
    Sent from my SM-G935F using Tsikot Forums mobile app[/QUOTE]
    Dec 2008
    #9345
    Quote Originally Posted by JAMES_007 View Post
    [/QUOTE]
    #9346
    Normal po yan patakbuhin mo ng mg 40 kph pataas mawawala na mag reset lng k c tinangal battery..
    Sent from my CHM-U01 using Tapatalk[/QUOTE]
    Thanks for reply sir, Kahit papaano medyo gumaan loob ko ^_^
    Mar 2017
    #9347
    That's good to hear sir na hindi talaga madaling masira ang push start. But what im trying to say sir is very sensitive ang electronic parts. Kahit hindi sa sasakyan na electronics kahit gaano pa ka pulido pag ka gawa at iningatan mo dadating din ang panahon na papalya yan sir. Paano pag na basa and nag short circuit? during WORST CASE SCENARIO.. sabihin po nating pumalya.. is there any bypass sa push start ng MUX? I've seen other cars kasi sir na pag hindi gumana ung push start nila, merong cla bypass sir na pwede nila gamitin ung susi.. d po ba mas maganda meron kang back up..
    Sep 2008
    #9348
    Quote Originally Posted by JaypeeUy View Post
    IMO, a push start button has even less moving parts than a conventional one, so less failure points. Kaya baka mas reliable pa nga ito.
    #9349
    before the key-twist start, was the push-button start. from what i remember, the push start button was more durable than the key-twist start mechanism.
    the key twist start was introduced as a convenience over the start button.
    times change.
    Jan 2017
    #9350
    Mga Sir, good morning. Has anyone of you experienced na parang di nagbabago ang Range ng MUX naten. Yesterday kc nagflash ung Low Fuel ko sa MID pero when I check the Range it is still 150km as per MID. May problem kaya sa MID? I know it is just a guide pero masyado atang hindi realistic...
    Your thoughts mga Sir.
    TIA....
    times change.
    Oct 2016
    #9351
    Sorry po, pero anu po ibig sabihin nun? Dati dito lang city takbo, naramdaman ko lang to after i long drive ko ng ilang araw.
    Sep 2011
    #9352
    Ibang car nalang bilin mo mukang kahit anung paliwanag sayo nakatamin nasa utak mo na madaling masira punsh start kahit naman may susi nasisira din
    Apr 2014
    #9353
    Quote Originally Posted by Unbreakable View Post
    HAHAHAHA harsh but I completely agree with you sir
    Mar 2017
    #9354
    Oh. Wag ka pong umiyak sir.. :3 nag tatanong lang ako kasi gusto ko bumili ng MUX. Hindi mo ba gets ung tanong ko sir? Im asking IF meron or PWEDE bang e bypass? Hindi ko sinabi sir na ayaw ko. Pero mas MAGANDA if MERONG BACK UP.. :3 hahahah.. init ng ulo.. 😂😂
    #9355
    Oh. Wag ka pong umiyak sir.. :3 nag tatanong lang ako kasi gusto ko bumili ng MUX. Hindi mo ba gets ung tanong ko sir? Im asking IF meron or PWEDE bang e bypass? Hindi ko sinabi sir na ayaw ko. Pero mas MAGANDA if MERONG BACK UP.. :3 hahahah.. init ng ulo.. [emoji23][emoji23]
    Sir para hindi na humaba pa. Walang bypass. Correct me if im wrong. Kung may nakagawa. Reply nalang kung meron.
    Better ask isuzu mismo kung kayang lagyan kung nag aalinlangan ka.. :-)
    Jul 2016
    #9356
    Ang bypass sa de susi na oto is to jump the starter relay pag nag loko susi or the starter signal switch itself.
    Siguro, your concern is not the "push button" itself na masira But more on na mag fail ung transponder or malow batt ung sa susi ng mga keyless/push start na keyfob. Alam ko, may slot na ipapasok sa somewhere sa dash para ma bypass ung built in transponder incase ma low batt or masira nga FOB.
    Mar 2017
    #9357
    Quote Originally Posted by Civic_Racer View Post
    Thanks sir sa info. i've done it already. i asked our local isuszu dealership and even isuzu philippines fb page and MUXownersphilippines but they told me na babalikan lang nila ako kasi hindi rin po nila ma sagot.. :3
    Mar 2017
    #9358
    Quote Originally Posted by Janemar View Post
    Yun sir, nakuha mo po ung tanong ko.. ^_^ salamat po sa info..
    Feb 2017
    #9359
    pag lowbat po transponder, kailangan lang nakadikit ang tronsponder sa start button, or better yet ang tronsponder ang ipang push sa start button..
    #9360
    Quote Originally Posted by MigeLlacuna View Post
    Correct po. Sometimes meron yung kotse physical na key fob pero hindi sya bypass. Kapag low or dead batt may paraan pa pero kapag sira transponder mo kahit i-jump mo ang starter e hindi parin tatakbo. Remember your key is also an electronic key it is specifically coded to your cars dme/ecu for it to start.
    In short if you are too worried about your electronic push start button failing..it is the same banana if your electronic key transponder fails.
All New Isuzu MU-X // Alterra Next Generation
