Page 467 of 607 FirstFirst ... 367417457463464465466467468469470471477517567 ... LastLast
Results 9,321 to 9,340 of 12125
    #9321
    Quote Originally Posted by Challenger75 View Post
    Care to take photos of the wheel wells? Best to bring it up with the dealer. I'm planning to have it rustproofed with ziebart after the dealer fixes it for peace of mind.
    Subukan nyo tangalin yun mga plastic cover dun nyo malalaman na need talaga full rustproofed. Be sure lng na tatangalin nila pkastic para lhat n pang ilalim malagyan.
    Sent from my SM-J700H using Tsikot Forums mobile app
    #9322
    Quote Originally Posted by Macky V. View Post
    Uhhhmmm. Mga Sir, normal ba ito, loose ung dikit sa gilid na rubber ng front windshield....
    if your windshield is attached to the body the same way as most other cars, ok lang po yan.
    the real water seal is a thick bead of butyl adhesive sandwiched between the glass and the metal frame. you can't see it, po.
    #9323
    but i could be mistaken.
    some manufacturers kasi, stick to proven, older methods....
    Jan 2017
    #9324
    Thank you Sir....
    Jan 2017
    #9325
    Thank you Sir...Got it
    Quote Originally Posted by doo View Post
    You're referring to the windshield drain plastic scuttle, it's removable kaya normal lang yan. I've once detached this and removed all the dirt and dry leaves that clogged the drainage.Attachment 34706
    Sent from my S59 using Tsikot Forums mobile app
    #9326
    Quote Originally Posted by JAZZZZZ View Post
    Btw, medyo ot. Ok lng po ba magpa blank ng egr kahit bagong labas sa kasa?
    On a personal note, ok sakin. I blanked our 2012 montero and 2015 fortuner. I wouldn't go as far to say it is imperative pero with my driving majority city ang bilis dumumi ng egr upon inspection.
    Sep 2012
    #9327
    Tama sir. And medyo conscious tlga ako sa black smoke hehe. Di kaya mavovoid warranty sir kahit walang cel?
    May 2016
    #9328
    Quote Originally Posted by crosswind View Post
    Here is the attached photo po sir. If it is clean medyo kita
    Sent from my SM-A700FD using Tsikot Forums mobile app
    Thanks for the photos. Wala naman ako na notice rust developing sa spots na iyan. Ang sa akin, mostly sa beam, across it and welds ng beam to chassis. Pero ayun nga, kailangan talaga ng rust proofing pa rin pala. Ayaw ko naman matulad sa Navara na nababalian ng chassis dahil kinain na ng kalawang.
    Sep 2011
    #9329
    Ano maganda car alarm para sa mux
    Mar 2017
    #9330
    Sir may tanong po ako. What if mag malfunction po ung push start button ng mux? Is there any other way to start the car? Pwede ba e bypass ang push start sir? If hindi pwede ma bypass, pwede ba mag pa install ng key ignition sir? Dba may provision naman dun sir?
    Sep 2016
    #9331
    Puwede susian sir let say nagkaproblem sa push start sir.
    Oct 2013
    #9332
    There is a recall for mu-X and D-Max, sa mu-X harness while sa D-max harness and brakes ata.. You can call you dealers for the affected production dates, basta 2016 models..
    Mar 2017
    #9333
    Quote Originally Posted by pomporumpum View Post
    Sir saan pa ung susi.an nun? Kasi sa nakita ko sir naka takip un. Pwede nyo po ba mapakita sakin sir? Nag aalangan po kasi ako kumuha sir dahil sa push start. Baka pag nag loko hindi ko na ma pa andar ang tsikot..
    #9334
    Push start button is pretty robust. I don't think you should worry about it failing anytime soon. In all probability more things will wear out faster on your car before the button.
    Mar 2017
    #9335
    Dba sir mas prone masira ang electronics? So pag nagkataon hindi mo na ma start engine mo pag pumalya.. during worst case scenario sir pag nangyari yan.. is there any other way na ma start mo engine mo?
    Jun 2012
    #9336
    Guys are they still selling the 4x2 ls-a at 2.5? Baka phased out na in favor of the 3.0.
    Jan 2013
    #9337
    Quote Originally Posted by JAZZforFUN View Post
    Sa Isuzu Bulacan nakakita ako ng pearl white 2.5 A/T noong 50,000 Km PMS namin, nadagdagan lang yata ng Cruise Control. 1.378M sa price list nila. 🙂
    Sent from my E6683 using Tsikot Forums mobile app
    #9338
    Quote Originally Posted by JaypeeUy View Post
    Sir that is a very sweeping generalization kapag sinabi nyo po na mas prone masira electronics. Syempre it depens on the use duty cycle at alaga mo. Remember ang use nya mainly is just to start and turn off the car. I'll bet your radio will see far more use than that. My cousin has an early mu-x kaya wala pa start button but just as per my own experience. My 2005 car had a start stop button never did it fail me until I sold it in 2012 and 82t kms later. Napalitan ko window regulator water punp alternator bearing but not the switch.
    Jun 2012
    #9339
    Quote Originally Posted by LancerA174A View Post
    Sa Isuzu Bulacan nakakita ako ng pearl white 2.5 A/T noong 50,000 Km PMS namin, nadagdagan lang yata ng Cruise Control. 1.378M sa price list nila. [emoji846]
    Ayos sir. Pero nagdadalawang isip ako kasi an additional 100k nlng you get the 3.0 variant hehe
    Mar 2017
    #9340
    Hi sir newbie here, I just want to ask about my mux LS A At (8N) 3.0L L.E. I want to install tv plus but the aux is for audio only Is there any way to connect it. Thank you and more power..
All New Isuzu MU-X // Alterra Next Generation
