* Mr X: He he...i share your observation sir. But then again, andun na. As for your question of after-market filters, I suppose marami, but you will still need a "sample" OEM filter so that any dealer will find the proper size for you.
Mag kaisa lang po ba ang cabin filter at aircon filter?
Saan kaya pwede mag palagay? Sa casa ba pwede?
Sent from my GT200 S using Tsikot Forums mobile app
Guys on our mux what is the acceptable computations of changing tires if i want to change what are the limit computations or acceptable conversion measurement kung 20" and 17" na mags.. ...mags and tires?😂😂
Sent from my CHM-U01 using Tapatalk
i usually use this when shopping / day dreaming for tires
Tire size calculator
Sir i did not change anything or settings it just came out from the casa na pede sila manood sa likod na while navi ako sa front..ang ginagawa ko lang set ko muna yung tv or video then in front of head unit i press SRC or NAVI button to select an option pede naman sya sa akin ng ganun sir...baka ang ginagawa nyo sir ay mauna yung navi then saka kayo mag video or tv then nawawala na yung navi nyo, try nyo baliktarin procedure sir...katulad sa akin video or tv muna set ko then after mag navi ako...
ok i try ko (movie first then navi)... usually 1 at a time ko pinapagana kasi ako lang mag-isa (di ko pa na check ang sabay na pag gamit), but last weekend drive sa malayo, navi poi first then movie (usb) para sa pasahero ko, at yun na yun, pag balik sa navi sa front nawawala na ang movie sa likod.
thanks, i will update sa result.
Hi all,
For our USB function sa video, may limit ba ang file size at 1GB ang pwede i play ? di ko mabasa sa manual na may limitation sa size.
Kasi sa 6 na full movie ko sa usb, 4 ang ok gumagana (video and audio) file size less than 1GB each, while ang other 2 files are more than 1GB (1 avi and 1 mp4) video lang ok but walang sound. All these files ay ok kung sa PC or sa TV ipa play.
Anyway i will try another file again na more than 1GB size.
Thanks.
Mga sir,para saan po ba yang horn na yan?
Sent from my B1-A71 using Tapatalk
Sa 17" max size without rubbing is 265/70/17 (using oem wheels)
Sa 20" 265/55/20 max offset 0
Anong unit? Sa LS/LSM max file resolution is 480p.
Sa LS-A alam ko 720p. Hindi rin naman high def yung monitor kaya no use ang 1080p videos.
Pinaka maganda .mp4 format, most of my videos work with that.
Para sa alarm/immobilizer:
How an immobilizer system works on Isuzu MUX LS-M - YouTube
3.0 4x2 AT
363 kms
29 litters
363/29 = 12.51724 kms/l
FT to FT
Thanks to MUX Boxer got my hood Lifter and most especially the MUX utility box
Sent from my GT-N5100 using Tapatalk
