Results 5,421 to 5,430 of 12125
January 25th, 2016 03:07 PM #5421
- Aug 2004
- 8
January 25th, 2016 06:20 PM #5422Caution lang mga bro just got my unit last fri sabi ko bat matagtag, paguwi check ko tire pressure 45! Kaya pala. Binaba ko agad to 35 hayun ok na kahit 29 ang standard pressure ng gulong natin.
Siguro standard pressure yung 45 pag nasa warehouse pa.
January 25th, 2016 06:41 PM #5423
Sir ok lang ba ang 35 ang pressure? Binaba namin sa 29 kasi yun nga ang suggested, may noticable improvement ba or difference?
January 25th, 2016 07:06 PM #5424
January 25th, 2016 07:18 PM #5425
i stand corrected. baka nga grasa. kung brake fluid e icheck kung nagbawas nga sa master cylinder. pero kung hi-miler yang oto e bababa talaga brake fluid due to pad wear.
kung sa hub nga mismo galing, either yung grasa mismo e baka yung low viscosity (kung yun nga ang tawag) like nlgi 2. pero baka naipon na moisture during its storage or netong mga nagdaang linggo na malamig na rin ang madaling araw.
subukan nyo isprayan ng tubig. kung mejo pumuputi yung tubig e brake fluid nga. kung hindi e baka grasa. other than that si bantay na talaga.
January 25th, 2016 07:29 PM #5426
Centered na centered ba ung andar ng MUX nyo pag naka gitna ung steering wheel?
- Dec 2008
- 60
January 25th, 2016 09:03 PM #5427^ ako sir may kabig sa kanan pagkakuha ko. Dito ako sa province. Pina align ko sa labas, as per advise ng SA. Balak ko iluwas sa manila para pa check alignment pos sabay 5k PMS na din.
January 25th, 2016 09:22 PM #5428
Centered naman sakin. Before getting an alignment check first tire pressure baka magkaiba kaya may kabig.
January 25th, 2016 09:26 PM #5429
January 25th, 2016 09:32 PM #5430
I had all tires checked for air. Same na lahat sila. Still have like an inch...left i need to pull.....kabig? When i center the steering wheel it goes right.
The hybrid release was also basically an all-new model release for TMPI, I think.
2021 Toyota Land Cruiser LC300
