Results 11 to 15 of 15
Threaded View
June 7th, 2010 12:38 PM #1
May na kapag try na ba mag install ng Alcohol injection sa XUV nyo? may available kasi sa SPEEDLAB at i think affordable na price ito compared sa NOS...
my bad side effects ba? nakita ko sa site ng speedlab MATADOR brandy pa gamit nila... sobra ok ito lalu na sa babad na akyatan like going ip baguo city.
according naman sa iba site puro maganda feed back. (which i think not always true ) What you guys think? should i be the 1st to try hehehehe
DevilsOwn's Benefits Include:
•Increase horsepower safely by 10-15%.
•Lower air temperatures by 50-200+ degrees.
•Decrease cylinder temperatures up to 300 degrees.
•Reduce the effects of heat soak in warmer climates.
•Allows you to safely run more boost and timing.
•Reduces carbon and helps maintain a clean combustion chamber.
•Increases octane at user programmable boost levels.
The main function of water methanol injection is preventing detonation. Detonation is caused by high temperatures and pressure developed in the combustion chamber. Water has a high latent heat content, which makes it extremely effective at preventing the onset of detonation. Water injection also reduces the production of NOx (oxides of nitrogen). Methanol, with its 116 octane and high flash point, further reduces the chances of detonation. While water is not combustible, it has a greater capacity to cool the intake air temps more than methanol alone. This is why we recommend a 50/50 mixture being misted into your boosted engine. Methanol also effectively increases the octane rating of the fuel, allowing performance gains when used in supercharged and turbocharged applications.
The assumption that the vehicle runs on the road, the ECU is more than likely a match. Try cleaning...
***HELP*** iding problem
