Results 1 to 10 of 12
- Apr 2009
- 551
May 17th, 2010 02:24 PM #1hello.. ask ko lang ilan ba talaga leafspring ng 2001 XTO?
i bought mine 2nd hand napansin ko kasi four pieces ang leafspring, na compare ko ito sa 2009 model na 5 pcs ang leafspring.
binawasan kaya yun ng dating owner para d matagtag?
thanks
May 17th, 2010 04:23 PM #2
- Apr 2009
- 551
May 17th, 2010 04:49 PM #3wow nice picture benzmizer thanks..
yung nakita kong 2009 i think its XT. taka ako bakit 5pcs leafspring.
May 17th, 2010 05:36 PM #4
You're welcome.
For our common reference, the Crosswind introduced the Flex Ride Suspension back in 2005.... and it's the same suspension that is still being used as of today. So it is likely that that 2009 XT you saw is already using the Flex Ride Suspension.
It does not automatically follow that if you see a set of (5) vs. a set of (4) leaf springs it means the former is "bumpier" than the latter. Leafs are made of the same structure but can vary depending on thickness --- which would have an effect on its ride and performance.
- Apr 2009
- 551
May 17th, 2010 06:34 PM #5yes I think your right the one I saw is a newer version probably what they
call flex ride.
thank you benzmizer
- Sep 2009
- 5
June 8th, 2010 11:56 AM #6
June 8th, 2010 02:00 PM #7
- Sep 2009
- 5
June 9th, 2010 10:48 AM #9
good day sir. ask ko lang din kung may tamang sukat ba ang leaf spring shackle? may mabilhan ba nyan na oem o pinafabricate lang? mine kasi parang fabricated na sya gusto kung palitan ng OEM pag meron. kasi nag DIY ako last time palit ng rubber bushing,yong nut bali 16mm pero yong rubber bushing parang 18mm sya. thanks in advance.
June 11th, 2010 07:14 AM #10
boss, ito ba yan?...
Waterless Wash & Wax
