Page 15 of 21 FirstFirst ... 5111213141516171819 ... LastLast
Results 141 to 150 of 204
    Jan 2008
    #141
    [size=6]go trooper>>>>>>>>>[/size]
    Jul 2003
    #142
    Quote Originally Posted by val_c4 View Post
    hi Nap,
    ask k lang if what do you mean na i tweak? wala ako kasi idea...paano ba un and how much aabutin nun?
    2nd, pls tell me what do i need to check re sa pagka convert nun in particular.
    thanks again!
    val
    Hi Val,
    Kung EFI na yan bighorn mo pwede mong kabitan ng performance chip see this link http://cgi.ebay.ph/Performance-Chip-...3A1%7C294%3A50
    Regarding sa convertion most nilalagay sa bighorn ay yung pang pajero gearbox yung gearbox okay naman ang problema yung pitman arm weld yun mostly minsan hindi mo halata ang pagkawelding. Yung pitman arm yun ang madalas bumibigay. I've seen once at marami na naka experience niyan kaya better check mong maigi at much better palitan mo kasi ikaw ang nakasakay dyan. Hindi mo alam kung kailan bibigay better gastusan mo nalang.
    Dec 2007
    #143
    I would like to second Nap's thoughts on ensuring the conversion was done right. iwas ka sa welding kung pwede. kakatakot yan. else palitan mo dapat ng orig power steering gearbox at pitman arm. I also drive one and its good for keeping. ave ko is 7.5km / liter mixed city/hi-way driving.
    Aug 2009
    #144
    Quote Originally Posted by s_quilicot View Post
    niwds,
    nakabili na ako sa blumentrit. 40k sariwa pa. (cyl head ng 4jx1).
    Hopefully matapos na bukas.
    sir.. saan banda sa blumentrit?.. i'm also lookng for a cyl head ng 4jx1. u mean sariwa? as in bago? nasira din ung cylinder head kasi overheat ung isuzu tooper namin.. ung 40k? how much is the labor?
    tanong lang po.. eh.. kasi nag ask ako sa kakilala ko. sabi nya if u plan to change the cylinder or the engine - may setting pa daw.. computer setting? totoo ba yan.. or kung cylinder head hindi na kailangan?
    any updates or news where can i buy cylinder head or 4jx1 engine?
    thank u sirs..
    Feb 2005
    #145
    Your 2003 Trooper is using a 4JX1-TC engine.
    As for the 'setting' required, I'd say any major repair (specially if change engine), you'd need to use the Tech 2 gadget. From my knowledge, only authorized ISUZU dealers have this. Maybe some guys who had major repairs on their Trooper's 4JX1-TC engine could validate this.
    I am still at a loss where you could buy a cylinder head or whole 4JX1-TC / 4JG2 engine. Blumentritt may have the cylinder head (40k according to SQ). And whate he meant as "SARIWA", would mean used but still in very good condition.
    Aug 2009
    #146
    niwds,
    Quote Originally Posted by Benzmizer View Post
    thank you sir benz. sana meron pa..
    Feb 2005
    #147
    Quote Originally Posted by baby_scar View Post
    I hope so too.
    Please keep us posted thru this thread on any developments to your search (and repair) of your Trooper engine...
    We only have hopes that you soon do....
    #148
    thank u sirs..
    40k at zercom. 1476 Batangas cor. Severino Reyes st. Sta.cruz manila. 252-5925.
    as of now kailangan i set ang ECU. too mean A/F mixture.
    Aug 2009
    #149
    ung 40k? mayroon pa silang stocks? is it reliable? cylinder head? how about the engine? kasi i ask sa banaue. the least i can get is 55k? i didnt ask discount.. sir, kilala mo naman ung doon ZERCOM? Trusted naman po? hindi sira ung benta?
    what do u mean by ECU? no idea po.
    Feb 2005
    #150
    You are correct SQ. So kailangan talaga ng Tech 2.
4jg2  tdic engine
