Results 11 to 20 of 23
- Oct 2006
- 6,249
December 30th, 2017 05:13 AM #11
- Apr 2009
- 551
December 30th, 2017 07:44 PM #12I brought it to the calibration shop the mechanic said the injection pump is fine, engine running well and no visible smoke.
but he cannot identify the problem so suggested to check the injection pump might be some parts that need to be replaced.
that's my last option.
Earlier today in desperation I replaced the clamps of the fuel hoses going to the fuel filter and sedimenter it seems like
its not that tight. OEM clamps are like clips so i replaced with clamps that has screws. i will give feedback tomorrow.
Thank you to all the advice. .
- Apr 2009
- 551
January 2nd, 2018 11:14 AM #13After replacing fuel clamps on the fuel hoses it did improve. idle goes down but
engine did not shut down. I think I have to replace the fuel hoses. its a 17 year old vehicle and oem clamps have no screws but clips might have lost its
'grip' .
- Aug 2014
- 391
January 3rd, 2018 05:33 PM #14Meron na bang leak ang fuel hose due to old fuel clamps?
My ride is a highlander, so 4ja1 din. A year ago, i have this engine issue na bigla na lang namamatay while running, kahit naka 4th gear. Biglang mag zero rpm, kakatakot nga, buti na lang nasanay ako, almost a year ko yun dinadala, hangang mag decide ako mag pa check ng Injection pump, overhaul ng injection pump pinagawa ko dun sa trusted shop. Yun pala, pumasok na ang oil dun sa shafting nung Pump connected sa engine, kaya namamatay bigla, after that and until now, so far di ko na na experience yun. 10K gastos ko replace nung shaft and other o-rings and ano ano pang rubbers.
- Apr 2009
- 551
January 4th, 2018 03:49 PM #15wala naming leak, wala rin akong naaamoy na fuel. napansin ko lang
maluwag yung hoses, madaling tanggalin at madaling ikutin even with clamps.
my next move it to replace the fuel hoses. yung dinala ko sa calibration ang sabi niya possible may oil sa pump. hindi ko lang ma understand saan galling oil, maybe from adding 2t everytime I fill up. hindi lang ako convince kasi maganda ang hatak and hindi naman mausok.
earlier on coldstart ni ramp ko sa incline (paakyat) bumaba rpm. pero kung pababa naman normal siya or flat road.
- Oct 2009
- 2,271
January 4th, 2018 04:54 PM #16ganyan problema ng kumpare ko sa XLT pamasada niya nag lolow power.ganyan ung dinadaing niya wala kayong pagkakaiba ng problema.diko lang alam kung pano na solve.ngayon matino na makina niya..
- Oct 2006
- 6,249
January 4th, 2018 05:34 PM #17
- Apr 2009
- 551
January 4th, 2018 06:39 PM #18kung I rev ko wala namang problem malakas ang hatak. yun lang pag steady
or park mo sa paakyat sa umaga bumababa rpm hanggang sa mamatay makina.
pero kung mainit na makina kahit naka steady sa paakyat hindi na mamatay makina
- Oct 2006
- 6,249
January 4th, 2018 07:21 PM #19
- Apr 2009
- 551
Probably looks like a Coke sakto. Yes, where did you buy it?
Fire Extinguisher for Car: what brand and type...
