Results 1 to 10 of 224
    Jul 2015
    Sir need ko po Help, saan po yun magaling na magkabit ng Crankcase Oilseal. 4ja1 isuzu fuego 2001 nakadawa na kasi ako palit pero nagleak pa din, Mahal pa nman nun oilseal 900each original po
    Jun 2010
    Quote Originally Posted by J. Navarro View Post
    if major repair, sa casa na lang po kahit wala na warranty yon sasakyan at least pwede mo siya ibalik kung sakali na mag leak muli, kesa paulit ulit lang ang repair, lalo lang maragdagan ang gastos mo.
    Apr 2015
    kakabenta ko lang ng 1999 fuego ko, then pinalitan ko parin ng fuego 2002 pero nka turbo na sya with 4ja1. bulletproof itong engine na to.
    Aug 2014
    Hi,
    I have a mechanic replaced the oil seal of the rear of transmission, the part that connected to propeller. But after a few days, I noticed that there is still a little drop of oil. Can anyone suggest what could be the other problem? is the seal not fitted properly (note: its an OEM Isuzu with correct part number). Hope someone can advise.
    Thanks
    Hi,
    Thanks
    Nov 2014
    Quote Originally Posted by aioshin View Post
    Hi,
    Thanks
    Hi,
    Thanks
    same sa akin yon pa balik-balik ang leak. Na resolved finally when we had the propeller shaft machined. Kailangan smooth yong area where the oil seal touches.
    Aug 2014
    Quote Originally Posted by alvin570 View Post
    Thanks sa advise. meron din nag sabi na pwede daw higpitan yung spring nung oil seal, pano kaya gawin yun?
    Oct 2015
    hi! noobie ako sa 4ja1. Paano ba gamitin yung manual choke knob? kapag hindi ba in use dapat ko bang turn yung knob fully counterclockwise (ikot pakaliwa)?
    thanks!
    Oct 2015
    tsk! double post!
4JA1 Engine, Are there any problems?
