From this video viewpoing, i think the next Mux will really look boxy from the sides
Hmmm
Hmmm
just found this on ************:
"4JJ3-TCX. Using high-pressure 250 MPa direct injection and electronically-controlled variable geometry turbocharger, it yields 190 horsepower at 3,600 rpm and 450 Nm of torque from 1,600 to 2,600 rpm. Meanwhile, the 1.9-liter RZ4E moves to its second-generation. And while outputs remain more or less the same: 150 horsepower at 3,600 rpm and 350 Nm of torque at 1,800 to 2,600 rpm."
the rz4 is carried over while a new more powerful 4jj3-tcx debuts.
They've finally adopted EPS pala. hmmm FC hasn't been announced yet but with EPS, FC should improve.
We might see this soon pala, since IsuzuPH doesn't assemble Dmaxs na pala.
Eto na actual unit sales agent basic run through, para ma-update na tayo lahat ambagal kasi dito sa Pinas eh , WYSWYG - what you see is what you get lol
Showroom actual unit! From the front fascia alone, i can imagine that the MUx gen 2 will also be a looker hihi
kaya pala isuzu is touting 545mm suspension travel or articulation. because its more than what the hilux can do - 520mm of travel. not yet sure if the tcs will be disabled when the diff lock is engaged.
btw its hydraulic assisted steering pala.
first impressions fron headlightmag is good overall. better than hilux and triton kuno.
