Almost all-new pala ang 4JJ3-TCX, forgot the name pero isang part lang carried over from 4JJ1.
- 4 million Kilometer durability testing
- More durable injectors
- Qieter timing gear set
- All-new frame, chassis, suspension built from the ground up
Sent from my H8266 using Tsikot Forums mobile app
Chance of 4jj3-tcx with isuzu ph is nil
Chance of 4jj3-tcx with mazdaph very high.
Hahahhah
Baka nga sa BT-50 pa magkaroon ng full suite ng active safety feats and in-house infotainment system [emoji28]
Denso's 250mPa I-Art fuel injection system is somewhat compatible with euro4 diesels.
Looks like we'll see the (third gen) next D-Max (RG) soon.
Confirmed: The all-new Isuzu D-Max will arrive in PH in 2021 | TopGear PH
clearing inventory
Isuzu PH is rolling out a P180,000 discount on the D-Max until December | TopGear PH
The all-new Isuzu D-Max is now in PH; prices start at P857k | TopGear PH
Isuzu D-Max RZ4E Single Cab MT- P857,000
Isuzu D-Max RZ4E 4x2 LT MT - P987,000
Isuzu D-Max RZ4E 4x2 LS MT- P1,219,000
Isuzu D-Max RZ4E 4x2 LS AT- P1,309,000
Isuzu D-Max 3.0L 4x4 LT MT - P1,288,000
Isuzu D-Max 3.0L 4x2 LS MT - P1,320,000
Isuzu D-Max 3.0L 4X2 LS-A AT - P1,390,000
Isuzu D-Max 3.0L 4x4 LS MT- P1,630,000
Isuzu D-Max 3.0L 4x4 LS-E AT- P1,825,000
IPC is also currently collecting additional security deposits on top of these SRPs in light of the DTI’s new safeguard duties, so take note that you’d have to shell extra with every new purchase.
Interesado ako dun sa 3.0 lt 4x4 na mejo bare-bones pero may pagkaangas ang specs. Pwede na for almost 1.3m dahil naka abs na. Ang problema lang wala ibang kulay kundi white.
Medyo bad trip lang you can't get an AT 4x4 unless you go for the most expensive model which is even pricier than the top-end Strada.
