Page 1 of 7 12345 ... LastLast
Results 1 to 20 of 137
    Sep 2011
    How do I start? Anong mga materials ang kailangan ko for cleaning? Anong parts ang mga lilinisan? What are the steps?
    Mar 2012
    2.5 Gal shop vac
    You can purchase art paint brushes to access dust in small spaces.
    A good glass cleaner except on tint
    Micro fiber towels (no lint type)
    A good foam type cleaner for the carpets
    A steamer is good to have
    i also wanna try doing this on my own.. thanks for sharing..
    Jan 2010
    Here's a sample guide from Mothers:
    MOTHERS® Polishes·Waxes·Cleaners
    Jun 2011
    mga sir ano po ba pwedeng gamitin for... DIY fabric seats cleaner?
    Jul 2013
    Well it depends on your interior type because the methods and materials are different on leather and fabric interior. We need more care to leather interior because that is more expensive and more sensitive as compare to fabric interior. First of all start with vacuum cleaner and then clean the dash with some good brand cleaner. Wash the mats and let them dry. Use some polish on dash to get shiny interior.
    Jan 2014
    ako na nga lang din ang titira ng interior ng car ko, masyadong mahal na ang pa detail eh..tyagaan na lng to hehehe
    Quick question, what would you detail first?
    - Leather seats, or
    - Dash and Sidings, or
    - whatever you can reach from where you're seated?
    Aug 2012
    Interior Detailing
    Detailing the car's interior is an equally important part of the detailing process. Why? Because that's where you and your passengers are most of the time.
    Vacuuming
    The first thing that needs to be done is to thoroughly vacuum the interior. If you don't have a good vacuum, then you're better off going to a local car wash. You need a strong vacuum to do the job properly.
    Use compressed air to blow dirt from cracks, under seats, between seats, AC vents and around windows, center console, dash, etc. Vacuum all interior parts, beginning with the headliner and moving downward.
    When vacuuming leather surfaces, use the brush tool to prevent scratching the leather. Vinyl and metal surfaces are not as delicate so use whatever tool is best for the job.
    Seats. The seats must have special attention. Use the crevice tool where possible. On all seats, make sure you vacuum the seams. Dirt lurks in there and will eventually cause wear and deterioration.
    Floor. The floor of the car is always the dirtiest part. Give the floor a good brushing followed by a very thorough vacuuming.
    Shampooing Carpet
    To do a really professional job, you'll need to shampoo the carpet with a commercial shampoo. Remove the carpet mats and shampoo them first. Use a water extraction machine or wet-dry vacuum to remove as much as water possible to speed the drying process.
    Example Products: 3M All Purpose Cleaner and Degreaser, Armor All Multi-purpose Auto Cleaner, Armor All Carpet & Upholstery Cleaner
    Vinyl and Plastic Interiors
    There are many vinyl/plastic cleaners and protectants. Some are all-in-one formulas, others are two-step. For deep cleaning, it is recommended that you wipe down all vinyl surfaces with a cleaner first, followed by a protectant/conditioner. For monthly maintenance, you may only need the all-in-one solution.
    Hard plastics like the gauge-cluster lens or overhead light won’t respond to most protectants and need to be polished much like paint.
    If you do not want a 'slippery' finish, avoid products that contain silicone.
    Example Products: Meguiar's Ultimate Interior Detailer, Meguiar's Ultimate Protectant Spray, Meguair's Gold Class Trim Restorer, Mothers VLR (Vinyl, Leather, Rubber), Mothers Protectant, Mothers Plastic Polish
    Leather Interiors
    When properly cared for, (genuine) leather upholstery will last far longer than other upholster material. Cleaning and conditioning leather is very similar to caring for your own skin. To safely clean leather you will need a neutral pH cleaner (4.5 to 7.5 pH) and a leather conditioner suitable for upholstery.
    As leather interiors take very small amounts of conditioner to properly care for them, premium, high quality products are your best choice.
    Example Products: Meguair's Gold Class Vinyl & Leather Cleaner, Meguair's Gold Class Leather Conditioner, Mothers Leather Cleaner, Mothers Leather Conditioner
    Fabric Interiors
    Unlike vinyl and leather, fabric upholstery easily soils and stains. Clean fabric by using spray-on/wipe-off cleaners, or shampoo and wet-dry vacuum combination.
    Example Products: 3M All Purpose Cleaner and Degreaser, Armor All Multi-purpose Auto Cleaner, Armor All Carpet & Upholstery Cleaner, Meguiar's Ultimate Interior Detailer
    Door Panels
    Door panels are cleaned based on their material. For fabric, use shampoo. For vinyl, use a vinyl cleaner to wipe down the surface, then buff with conditioner. Likewise, use the appropriate cleaner/conditioner for leather.
    Interior Glass
    Clean interior glass using a two-towel method for best result. Use one towel for the initial wipe after applying glass cleaner. This removes majority of the dirt. Use a second towel for final wipe down to produce streak-free glass.
    Cleaning tinted windows requires special care. Don't use ammonia-based cleaners.
    Example Products: 3M Premium Glass Cleaner, Armor All Auto Glass Cleaner, Meguiar's Perfect Clarity Glass Cleaner, Mothers Glass Cleaner
    Nov 2014
    Reviving this thread because I just bought this 3M Scotchguard Fabric Protector for my car seats, which are upholstered in dark fabric.
    It's in an aerosol can, with reminders to ensure good ventilation during application and to avoid overspray on other areas.
    Question for the Tsikot detailing gurus: Do I need to remove my car seats (never attempted this before, no idea how yet) so I can freely spray them or can I get away with applying this inside the car?
    Mar 2017
    Quote Originally Posted by kai s. View Post
    I'm no guru, but I used Scotchguard on my carpet. I just opened all the doors and windows, and made sure to let the product dissipate before moving on to another area of the car.
    Mar 2004
    You can spray them inside the car, just have a wiping cloth nearby for when you over spray ... air out the car a couple of hours ... not too early and not too late to avoid mosquitoes ... used about 2 to 2.5 cans on a sedan ... did a double layer application ... take note though that most modern car seats are somewhat water and stain resistant already ... search online about how car manufacturers choose materials for their car seats ...
    Aug 2012
    I use the same product. But first, I use 3M Scotchguard Fabric Cleaner. Also in spray can. Next, I use 3M Scotchguard Fabric Protector. My stock car seats are Black. I spray them inside the car.
    Sent from my ASUS_Z010D using Tapatalk
    Nov 2014
    Quote Originally Posted by AllenR View Post
    Thank you! Good to hear from others who've used the same product
    Ohhhh I have to buy another can first. I was too optimistic and bought only one hahaha
    Quote Originally Posted by red_one View Post
    Hmm I have Microtex Quickleen, okay lang naman siguro to use from another line? Or (I'm hopeful haha) skip it altogether since I think my seats are still somewhat clean. This is more from reluctance to add another few hours to dry the seats completely before coating.
    Mar 2004
    If you're spraying just one layer ... 1 can will do ... use up your can first before buying another one ... also 1 layer is ok already ... just respray after a couple of months ... stopped using this ... now using a bath towel that color matches seat color ... easier to remove and clean weekly compared to a seat cover ... buy 2-3 so you have spare ... it will still be many times cheaper than a seat cover ...
    May 2017
    Remove the dusts and dirt first. I suggest a good vacuum. This vacuum from Type S is a good one. The suction power is strong and the motor sound is not that loud so you wont disturb others while vacuuming. Here's a photo for reference:
    It's available in True Value, Handyman and DIY Shop. Srp is around Php 1,990
    Mar 2004
    Type S branded items have poor quality ... also avoid their wipers ...
    Mar 2017
    Saw a small (4L) Shop-vac vacuum in Lazada for less than 3k.
    Sent from my E6853 using Tsikot Forums mobile app
    Aug 2012
    Get the Shop-Vac Micro model. It is not expensive. Good for car and home use. Small, portable, powerful.
    Mar 2017
    I second this. Based on my experience with the 30 liter pro model, very reliable pa and can be used for wet vacuuming.
DIY Interior Detailing
