Page 2 of 7 FirstFirst 123456 ... LastLast
Results 21 to 40 of 137
    Jul 2015
    #21
    What leather seat cleaner and conditioner without the greasy and glossy finish would you recommend?
    It's for a black leather interior.
    TIA..
    Apr 2017
    #22
    May alam ba kayong pang linis sa leather trim something sa sides ng Fortuner 2016? Mejo nadudumihan na eh
    Sent from my SM-G928V using Tsikot Forums mobile app
    #23
    Quote Originally Posted by red_one View Post
    Get the Shop-Vac Micro model. It is not expensive. Good for car and home use. Small, portable, powerful.
    Sent from my ASUS_Z010D using Tapatalk
    i have this. double purpose since it is both a vacuum cleaner and blower in one. pwede mo ikabit yung hose sa air outlet and it becomes a blower that is good enough for cleaning or drying air filters or inflating a portable swimming pool. lakas din nga pala ng vacuum
    #24
    Quote Originally Posted by MatchuPichu0324 View Post
    pledge lang gamit ko and satisfied with the results. di ako bumibili nung mga supposedly specially made for cars na cleaners, mahal presyo pero parehas lang naman o mas maganda pa yungbtried and tested leather furniture cleaner and wax.
    Apr 2017
    #25
    Oh. Natatanggal niya yung dumi just by wiping it with pledge? Ano gamit mong pamunas sir?
    Apr 2012
    #26
    Quote Originally Posted by chickentuna View Post
    Guys dahil sa anti distracted driving law, tinggal ko yung santo sa dashboard ko. May puting marks ng double adhesive. Tinry ko na baby oil, nawala pag ka sticky pero parang kumalat yung white residue. Nag try din ako nung armor all all purpose cleaner + microtex protectant combo. Ok at first pero pag nawala na effect ng protectant parang namumuti na ulit yung part na pinaglagyan ng santo. Any tips para mawala yung stain at mag pantay ulit yung kulay ng dashboard?
    Sent from my Mi4c using Tapatalk
    kung may adhesive pa na naiwan, try mo gamitan ng Glue Gone spray. if namuti na talaga at nag etched na sa dashboard, baka hindi na papantay kulay niyan...
    May 2012
    #27
    Ano po ang magandang panlinis or pang pahid or pang spray sa interior carpet? Yung tipong dadaanan or papahiean mo lang po ng mild danp cloth with a good smelling chemical..
    Joy? Downy? Carpet cleaner?
    Sent from my ASUS_T00I using Tsikot Forums mobile app
    #28
    yes. just spray on, let it soak for a minute or two, wipe off with a bit of down pressure to get to between the creases and stitches. no special "pamunas", i just used my oldest 3m glass cleaning rag but any cloth will do.
    Jun 2017
    #29
    Here are some creative/weird car designs you could use if ever you guys wanted to some DIY Interior designing. Me I personally prefer to DIY my interior since it's my own car and whatever I want do with it either make it look fancy or whatsoever. Hope this helps
    Jun 2017
    #30
    Any product you can recommend for concealing/fixing dashboard scratches?
    Jul 2017
    #31
    Hi, has anyone tried the ff cleaner ingredients
    Water
    White vinegar
    Baby Oil
    Cleaner for vinyl and plastic
    Jul 2004
    #32
    What brand would you recommend na pinaka magaling and available sa Pinas for cleaning interiors?
    Mother's?
    Meguiars?
    etc?
    Aug 2013
    #33
    Quick question, what would you detail first?
    - Leather seats, or
    - Dash and Sidings, or
    - whatever you can reach from where you're seated?
    For you to be able to reach dash/sidings/roof you need to utilize that seats so last touch would be the seats...
    Oct 2018
    #34
    For cleaning interiors, I use Microtex Quickleen and a microfiber tower to loosen the grime. I spray and let it sit for a while then wipe with wet microfiber towel. Before it dries, I wipe the panel down with a wet melamine foam. Guaranteed back to original
    Mar 2018
    #35
    Quote Originally Posted by bogart.2006 View Post
    I use this too. Very handy and effective.
    Oct 2018
    #36
    Quickleen is good but it's the melamine pads that does the trick.
    Apr 2012
    #37
    i use Mother's VLR interior cleaning, effective sa leathers at interior trims.
    where to buy melamine foam? is it similar to magic eraser?
    Oct 2018
    #38
    Its actually the same but cheaper. Japan home
    Apr 2012
    #39
    okay, thanks
    Oct 2018
    #40
    okay, thanks
    no prob. the other good thing about the cheap "magic erasers" is it's not that aggressive. it does the job of cleaning vinyl, plastic and leather but is not that strong that it will peel off coloring like magic eraser does at times.
    i usually test out a small area na hindi nakikita
DIY Interior Detailing
