Page 5 of 7 FirstFirst 1234567 LastLast
Results 81 to 100 of 137
    Feb 2019
    #81
    Quote Originally Posted by sirkosero View Post
    Bumili ako nung rivers na degreaser sa lazada noon. Netong quarantine, nagspray ako ng ng kontinsa ceiling then wipe. Mabilis lang. Tanggal yung dumi agad eh.
    Sent from my MI MAX 2 using Tapatalk
    I think degreaser is use more on the engine bay right? It is much stronger compared to an all purpose cleaner for interior.
    Jun 2005
    #82
    if it works then ok naman yan, pwede mo rin i-dilute sa water para hindi masyadong matapang. for interiors, mas prefer ko gamitin all purpose cleaner (apc) kesa degreaser.
    Yup. Forgot to mention diluted din sa water. Masyado matapang yung puro.
    Jun 2005
    #83
    I got the APC and the degreaser version. Pareho lang naman sila ng amoy.
    O think yung APC is just watered down degreaser.
    Feb 2019
    #84
    So you spray directly to the ceiling and wipe it off using microfibre cloth? can it also be sprayed in microfibe cloth then wipe? I never tried cleaning the headliner in my whole life lol.
    Jun 2005
    #85
    Either way worked for me. Luminis naman headliner so im a happy camper
    Feb 2019
    #86
    Okay thanks sir. Interior detailing charge me high price that's why I opt to resort DIY.... imagine yellowish headlamp they will charge me 1500 to make it crystal clear again.
    #87
    the easy and longer-lasting solution, albeit more expensive, is to replace the yellowed headlight assembly.
    Feb 2019
    #88
    Oh that would be much more expensive. I just want to remove the yellowish haze in the headlamp im ok if it will not be 100% clear at least it will become cleaner.
    Feb 2019
    #89
    My purpose is to protect the car paint and when it rains I want the droplets to just slide down to prevent watermarks. Is this the right product for it or do you have other recommendations thank you.
    #90
    There is an improved TW ICE Seal n Shine announced by Pan the organizer.
    YouTube
    Feb 2019
    #91
    Is there a way to make dirty seat belt restore to its original color? I was trying to use the microtex pro cleaner and brushing the belt with toothbrush but to no avail.
    Feb 2019
    #92
    I will try to restore my yellowish headlight tomorrow diy using grit 1500 and with grit 2000.... then finish it off with rubbing compound can I use either 3M or turtle wax for headlight are they the same and any tips? as to not damage the headight.
    Jan 2008
    #93
    perform wet sanding, any rubbing compound will do to polish the surface. you also need to consider the top coat to apply after polishing.
    Feb 2019
    #94
    Yes i will do wet sanding.... hmm havent consider a top coat what can I use?
    #95
    may pic ka bro? baka lumaki muscles mo sa 1k - 2k grit agad
    Sent from my RMX2020 using Tapatalk
    Feb 2019
    #96
    It is in the garage tom il take photo. So any suggestion on sandpaper grit as this will be my first time doing it. I just saw on youtube he uses 1500 and 2000 grit.
    #97
    depende sa condition bro
    worst is 400 - 2500 grit (kailangan tanggalin nabulok na clear coat)
    if ok pa clear coat 1k-2.5k lang
    Feb 2019
    #98
    Okay bro. I wanted a detailer to do it but they are charging me Php3,000 for a pair of headlight restoration a bit heavy on the pocket thats why I resort to diy.
    #99
    if labas lang bro DIY mo na nga lang
    less 200 materials, 300 pag may clear coat
    Interior steaming diy... ano need nito? Ito yung uso ngayon i think to kill viruses while making your interior smell good, right?
DIY Interior Detailing
