Results 11 to 20 of 138
May 14th, 2017 08:38 AM #11
May 14th, 2017 04:03 PM #12
You can spray them inside the car, just have a wiping cloth nearby for when you over spray ... air out the car a couple of hours ... not too early and not too late to avoid mosquitoes ... used about 2 to 2.5 cans on a sedan ... did a double layer application ... take note though that most modern car seats are somewhat water and stain resistant already ... search online about how car manufacturers choose materials for their car seats ...
- Aug 2012
- 2,767
May 15th, 2017 08:07 AM #13
- Nov 2014
- 1,269
May 16th, 2017 12:38 PM #14Thank you! Good to hear from others who've used the same product
Ohhhh I have to buy another can first. I was too optimistic and bought only one hahaha
Hmm I have Microtex Quickleen, okay lang naman siguro to use from another line? Or (I'm hopeful haha) skip it altogether since I think my seats are still somewhat clean. This is more from reluctance to add another few hours to dry the seats completely before coating.
May 16th, 2017 07:18 PM #15
If you're spraying just one layer ... 1 can will do ... use up your can first before buying another one ... also 1 layer is ok already ... just respray after a couple of months ... stopped using this ... now using a bath towel that color matches seat color ... easier to remove and clean weekly compared to a seat cover ... buy 2-3 so you have spare ... it will still be many times cheaper than a seat cover ...
- May 2017
- 2
May 19th, 2017 12:12 PM #16Remove the dusts and dirt first. I suggest a good vacuum. This vacuum from Type S is a good one. The suction power is strong and the motor sound is not that loud so you wont disturb others while vacuuming. Here's a photo for reference:
It's available in True Value, Handyman and DIY Shop. Srp is around Php 1,990
May 21st, 2017 12:39 PM #18
Saw a small (4L) Shop-vac vacuum in Lazada for less than 3k.
Sent from my E6853 using Tsikot Forums mobile app
- Aug 2012
- 2,767
May 21st, 2017 12:55 PM #19Get the Shop-Vac Micro model. It is not expensive. Good for car and home use. Small, portable, powerful.
Sent from my ASUS_Z010D using Tapatalk
May 21st, 2017 12:57 PM #20
I second this. Based on my experience with the 30 liter pro model, very reliable pa and can be used for wet vacuuming.
For the Toyota products its likely to be the case for most of their products per the service...
Wheel Alignment
