Results 31 to 34 of 34
April 13th, 2009 04:18 PM #31
If the condition of your interior upholstery is still ok, except for the stink, doing a full interior detail would be hitting two birds with one stone; it gets cleaned and de-odorized.
June 6th, 2009 01:12 PM #32
June 27th, 2009 10:38 PM #33
if you read it carefully the chlorine crystals nor the solution was never made to contact anything inside the car.
hindi po yan inilagay directly on any surface inside the car. chlorine is very volatile and once you dissolve it in water agad yan sisingaw. ilinagay sa glass jars at pinasingaw sa loob ng car lang. disinfectant ang effect.
now if you actually pour it on anything inside the car or place it in an unstable container and it leaks inside the car, sira ang surface (or mag mamantsa) na tamaan. Hence only use wide mouthed jars.
chlorine crystals may be bought in many hardware and sari sari store (as bleaching materials).
simple di ba?
June 28th, 2009 02:18 AM #34
yellow lysol works form me kapag may amoy nabasang carpet dahil sa tag-ulan.
Xiaomi E-Car
