Results 1 to 16 of 16
    May 2009
    I finished cleaning the external surfaces of the Sporty so as part of the habit whenever cleaning our cars, to clean the engine bay as well.
    I guess it will be a while before I need to clean it. LoL.
    How I wish it would stay this clean for the life of the car, impossible I know, just wishful thinking on my part.
    What waterless methods do you use to maintain your engine bays? I always used the Microtech foam spray and rag method. Perhaps there are more effective ways and products nowadays?
    May 2018
    Back when my cars didn't have computers, I'd wrap the alternator, distributor and battery connectors with plastic and let loose with a hose & detergent.
    Nowadays I just use a magic duster for all loose dust, then follow with a damp rag.
    May 2009
    Quote Originally Posted by SoleusBB View Post
    Same here sir, old-school carburetors, foam-type overhead air filters, distributor caps and spark plug cables (1,3,2,4), hehehe.
    I think I even used Tide pwder back then, much to the anger of my mom.
    Apr 2012
    i used the old way of degreaser spray, agitate with brush, rinse, wipe dry, apply protectant. it works for me
    May 2009
    Nice. May I ask what kind or brand of degreaser and protectant you use sir Monty?
    Apr 2012
    Quote Originally Posted by sparc179 View Post
    i can't remember the brand, its the cheapest degreaser in DIY shop near home. meguiar's back to black as protectant and trim restorer
    May 2009
    Copy and thanks for sharing your input sir, I might try that Meguiars product for the plastic parts.
    a dry or moist basahan. the round platito-sized ones sold by the road hawks is fine.
    May 2009
    I used those for the flat surfaces Doc, but unfortunately they won't be effective for all the little nooks and crannies of the engine.
    Too many tubes and hoses underneath the cover.
    Might go with a small brush usually meant for cleaning baby bottles, then a clean rag afterwards. A pistol cleaning kit would probably be good for the really tight corners and small spaces in between all of the fuel and electrical parts.
    I'm more interested in the kind of cleansing chemicals that some of our fellow tsikoteers use, something effective but obviously not toxic or will make the plastic and rubber parts brittle and yet not sticky to dust and grime either.
    Scotchgard for engines, if you will.
    Apr 2012
    detailing brush with long handles do the trick in reaching hard to reach areas and tight spaces. a spray of degreaser will surely loosened even the most stubborn dirts and oily grimes with ease. rinse thoroughly after and wipe dry especially the rubber hoses as it may react with the degreaser if not remove. waterless wash like the optimum no rinse is also one product that i frequently use and equally effective to clean the engine bay.
    Oct 2003
    Most of the time ang gamit ko lang is APC. Agitate with wheel and speed master brush. Rinse down, pa-dry ng kaunti then spray ng protectant after. After it dries ng kaunti, wipe down para matte finish.
    May 2009
    Now there's a good suggestion, detailing brushes, even old toothbrushes would be helpful me thinks. Degreasing agents may weaken rubber parts and plastics so I'm looking at other options as well.
    Thanks agaun sir Monty.
    Quote Originally Posted by zechs View Post
    What kind or brand of All-Purpose Cleaner do you use sir Zechs? Also, protectant?
    I mostly use Microtex, but looking at other available products as well.
    Oct 2003
    Microtex APC. May benta silang 1 liter concentrate. Dilute mo 1:4 then lagay sa spray bottle.
    Protectant na gamit ko ngayon is Carpro Perl diluted 1:1. Pwede din megs hyperdressing or kung tipid mode ka, microtex all season dressing diluted din 1:10 ata.
    May 2009
    Great! MicroTex it is then, I enjoy using their products. Not too expensive, yet effective nonetheless.
    Thanks again sir Zechs.
    Aug 2013
    I use the Rivers Degreaser from Lazada. Mga ₱200 na lang per gallon. Pati Shampoo and APC nila. Dati ₱300+ yun.
    Sep 2018
    Our car engine bay can look dirty as we drive it in the long run. It can be covered by grease or oil, dust, mud, dirt, and rust which will vary on your usual route. My usual step to clean my engine bay is by dry cleaning it followed by wet cleaning. Afterward, I will dry the engine and check some parts for detailing. With the right tools and material, we will be able to clean it accordingly. However, if you're not sure of the process, it would be best to have your engine bay cleaned on your trusted car shop.
Engine Detailing, what do you all use?
